Check engine light faulty egr valve help me diagnose the problem.
Old Sep 29, 2010 | 03:32 PM
  #31
theblackdahlia's Avatar
Originally Posted by Evo Tengoku
I got P0401 a few weeks back. Turned out one of the hoses popped off. Check for loose vacuum hoses before you spend $$$ on parts/labor.
thanks a ton. have had this code for a while and as i was reading thru this i ran down and stuck my hand in there and sure enough a loose hose had popped off the bottom. thanks for bein geniouses for sure
Old Jul 14, 2011 | 01:07 PM
  #32
dy4anEvo's Avatar
this is awesome info glad to finally have found a few pages on the valve....and a question i have is, if this valve were bad or not working properly(loose hoses), would it cause the engine RPM to run-on inbetween shifts or at low boost and letting off the pedal?
Old Mar 21, 2012 | 05:45 PM
  #33
richdegrave's Avatar
Same thing was going in my evo dumb little hose Mitsubishi should have put a better design for that hose I hate stupid emission equipment
fostytou
359
Oct 23, 2025 09:54 AM
rcheung
Jan 28, 2016 04:44 PM
Chris EVO 8
Aug 9, 2014 08:03 PM
Nominox
Aug 1, 2014 09:39 AM
Tommytooth
Mar 1, 2013 08:45 AM
