Need Help Guys Real Badly
Old Jan 1, 2009 | 02:05 PM
BadBoy818_818's Avatar
ok , i installed a greddy profec B spec ll on my evo IX MR/SE , i live i armenia and its the only evo here so i need help fixing it myself i installed it it worked fine except i had a burned clutch so i never got to test it i didnt know how to use it but i checked the boost gauge and it didnt pass 0.5 kg/m3 so i know i havent messed up my engine i was listening to some music while the car was turned off and my battery died i tried starting the car so it could charge the battery but didnt have enough power i changed the battery now it wants to start but it doesnt wat could be the problem?(i have gas in the car ) and the battery is full it says on the gauge?
Thnx
Old Jan 1, 2009 | 02:28 PM
evodood's Avatar
Start from sctrath. Take everything out and put your car back the way it was. Disconnect the battery for 2minutes to reset the ecu. Then start it and see if it's ok. If it is, the issue was with your install. So reinstall and be more careful.
Old Jan 2, 2009 | 03:57 PM
well before i do that , do you guys think its worth it if the car after installing the boost control was working just fine , it started not starting after my battery died and i charged it now it wont start and the battery is fully charged
Old Jan 2, 2009 | 06:31 PM
Speed Corps's Avatar
Former Vendor
You check your fuses. The culprit may be the one under the hood. I have had this happen where my gauges didnt work and my car wouldn't start. Take a look.
Old Jan 3, 2009 | 07:24 AM
well , everything works fine the car just doesnt start , I'll take a look at the fuses but lets say that isnt the probleme what else can it be?
Old Jan 4, 2009 | 03:33 AM
help out guys
Old Jan 5, 2009 | 03:21 PM
evodood's Avatar
You've go my $0.02 already. I would first wanna know %100 whether it's a car issue or a wiring issue. ONLY way to be %100 cetatin is to take it out.
If you'd have done it already you wouldn't still be trying to figure this out 4 days later. :P
awda5fk
Sep 19, 2015 08:59 AM
marell31
21
Sep 14, 2012 06:29 AM
evo panda
Oct 14, 2009 12:09 AM
Kevin Knight
Dec 4, 2007 02:50 PM
Evo8
May 15, 2006 05:57 PM
