Turbo IX question!
Old Jan 3, 2009 | 08:40 AM
evolved0414's Avatar
Turbo IX question!
Hey, I'm doing my IX turbo install right now, but i just looked inside of my box and I didn't get the j-pipe along with the turbo, I have everything else...
Is it at all possible to use the 8 turbo j-pipe?? could you bend it or anything to make it work??
Old Jan 3, 2009 | 08:42 AM
Psquared's Avatar
You talking about the lower intercooler pipe? Or the turbo outlet pipe that's black in color?
Old Jan 3, 2009 | 09:14 AM
RE: interested
It's the black pipe...
hopefully i can bend it or manipulate it somehow to make it work.
Old Jan 3, 2009 | 09:17 AM
Psquared's Avatar
Hmmm. The IX turbo install "kit" usually comes with that black pipe and all hoses for coolant and oil. I don't know if you can bend it much to accomodate your LICP for fear that it may crack. Def. heat it if you are going to try to bend it.
Old Jan 3, 2009 | 09:33 AM
Yea, I would def heat it up before bending it...
I think it might work if I can bend it just enough...plus it'll save me the trouble of having to get the kit.
Anyone else with any advice??
Old Jan 3, 2009 | 09:37 AM
Psquared's Avatar
Well...with couplers, they are a little more bendable to attach your licp to the outlet pipe. You using a stocker licp or aftermarket?
Old Jan 3, 2009 | 09:57 AM
I'm on the stock LICP which def helps...
Old Jan 3, 2009 | 12:25 PM
sparky's Avatar
You know that the problem is that the VIII J-pipe used in conjuction with the IX compressor housing contacts the starter and sparks will fly.
Old Jan 3, 2009 | 12:41 PM
Evo8uk's Avatar
Im not 100% on this but im sure i read that you can turn the compressor housing round slightly so the VIII J pipe can be used.
Old Jan 3, 2009 | 12:45 PM
markymark1082's Avatar
I have also heard that it will cause contact with the starter and cause sparkage.
Old Jan 3, 2009 | 01:11 PM
ScorpionT's Avatar
Just order the kit, its cheap and you wont have problems.
Old Jan 3, 2009 | 02:14 PM
VRSF Tiago's Avatar
Originally Posted by sparky
you know that the problem is that the viii j-pipe used in conjuction with the ix compressor housing contacts the starter and sparks will fly.
+1
Old Sep 30, 2009 | 06:54 PM
ethan169's Avatar
where is the best place to get the install kit from? and what should it cost?
Old Sep 30, 2009 | 07:23 PM
Jim in Tucson's Avatar
Here is the list. Order the parts from www.mitsubishiparts.net
Quantity Part # Description
1 - 1515A057 Fitting, Air Output $37.91
1 - MR281085 Gasket, Air Output $2.74
1 - 1310A171 Pipe, Water Return $8.38
1 - 1310A248 Pipe, Water Feed $8.38
1 - 1225A042 Tube, Oil Feed $7.89
2 - MF660063 crush washer @ $0.79
2 - MF660064 crush washer @ $0.93
4 - MF660065 crush washer @ $0.57
1 - MN156738 gasket for the oil return tube on the bottom of the turbo $1.34
Shipping: $9.95
Total kit price was like $82.47. Pic of kit in this thread:
https://www.evolutionm.net/forums/mi...stall-kit.html
Old Oct 1, 2009 | 01:47 AM
MR. EVO MR's Avatar
i had the same problem when i installed my fp-red, the silicone coupler from the j-pipe that came with the install kit touched my dump tube, i then put back my 8 j-pipe and it worked not realizing it was touching my starter wires.
unfortunately from that mistake i now have a new starter and built engine.
MAKE SURE IT DOESNT TOUCH THE STARTER WIRES!!!!!
GL
4G63_Crazy
May 31, 2017 08:07 AM
seven10
Nov 29, 2016 09:42 PM
Anubis18
Dec 24, 2015 02:23 PM
mitsuclipsegsx
Mar 8, 2011 08:06 PM
Braydo25
Jun 8, 2010 08:41 PM
