Magnecore 8.5mm wires not fit IX?
Old Jan 3, 2009 | 09:37 AM
I4UnderPressure's Avatar
Picked up a set of the Magnecore 8.5 wires from a member on here that ordered them from lancershop.com/ Anyhow I went to install them today, and they do not go all the way into the cylinder and create a "seal". They stick a bit above the top. I checked the length of the rubber boot and its the same length as stock. However, I then checked the inside and the stock ones have the conductor farther up the boot and the magnecore is more near the bottom, which is of course why it will not seal. Did I perhaps purchase a set for an EVO 8? Or do they use the same plug wires?
Old Jan 3, 2009 | 09:42 AM
90GSX-03EVO's Avatar
Yep. It's a known problem that they don't fit. Magnecore was great for DSM's, not so much for the Evo.
Old Jan 3, 2009 | 09:59 AM
What kind of upgraded plug wires do you recommend that will fit?
Old Jan 4, 2009 | 10:26 AM
How much horsepower are you making? Less than 500 WHP? If so, stick with the stock plug wires. If more than that, get the SparkTech coil-on-plug setup.
talonkev
Oct 22, 2016 11:18 AM
nytalonTSi
Oct 13, 2010 05:44 PM
bryans2k
24
May 29, 2009 01:47 PM
peter*g
Feb 10, 2007 09:23 PM
8ASTI
Jun 21, 2005 06:50 PM
