how much boost can it handle
Old Jan 4, 2009 | 07:52 PM
evokid511's Avatar
hey everyone im sure this has been covered somewhere on the forum but i just cant find exactly what im looking for so sorry( to all those that feel like flaming)
just wondering if 24lbs is to much for stock studs?? i have intake full TBE w/ o2 housing, boost controller at 24lbs, and 3" FMIC... ive heard you can run 25lbs safely but not to sure about that??
thank you all very much and sorry again haha
Old Jan 4, 2009 | 07:56 PM
evokid511's Avatar
oo yeah on 93 pump gas
Old Jan 4, 2009 | 07:58 PM
apeximprt2nr's Avatar
24psi is fine...my next mod would be to upgrade your studs when you have cams done.
MitsuJDM's Avatar
I'll admit, the search function has been pretty lame latley...
Anyway, you'll be fine with a safe tune.
Old Jan 4, 2009 | 07:59 PM
evokid511's Avatar
ok thaks that was really worrying me... thats exactly what i plan on doing next headstuds and cams... you think it is worth it to do headstuds now then cams later or no point??
Old Jan 4, 2009 | 08:01 PM
TheDream's Avatar
do them at the same time
evokid511's Avatar
yeah thats what i figured
Old Jan 4, 2009 | 11:11 PM
justa4banger's Avatar
im on a 8 turbo at 29psi on e85 and stock head bolts
Old Jan 4, 2009 | 11:18 PM
evil_eagle's Avatar
Same here, no issue so far (knocks on wood)
Old Jan 4, 2009 | 11:36 PM
sikrsix's Avatar
Thats cuz you are both on e85. Second post states he is on 93. Your tune decides your boost levels. Your timing plays a role in boost and knock, so there is no "set" boost level. Every car is different.
Old Jan 5, 2009 | 12:13 AM
lemmonhead's Avatar
as long as you dont knock you can run 30psi with no problem. Detonation pressure causes the issue not just boost your running. I say 25psi with some little knock is fine on the stock headstuds and no need to do it.
