Any experiance with this clutch? ACT 6 puck?
Old Jan 7, 2009 | 02:15 PM
  #31
RoadSpike's Avatar
6 Puck Sprung with prolite flywheel.
Grabs like a champ and isn't hard to drive. Only annoyance is trying to do a light slip, the clutch really wants to chatter a bit unless you give it a bit more goose. Its almost like an always in attack mode clutch, definitely livable for daily driving.
Old Jan 7, 2009 | 02:17 PM
  #32
beemerfreak's Avatar
If you have Tephra's NLTS you wont have lockout issues.
Old Jan 7, 2009 | 02:21 PM
  #33
Erik@MIL.SPEC's Avatar
So people running the sprung 6 puck disc are say it's a pretty good trade off. I would assume the unsprung disc is a lot more like an on/off switch compared to the sprung disc.
Old Jan 7, 2009 | 02:27 PM
  #34
Evolessfornow's Avatar
Same experience I have. Same set up. It's chatters unless you're over like 1500 RPM when you get going. Still getting used to the throttle too since the flywheel is so light. Either I don't give it enough gas or I'm above 2k RPM when I take off.
Old Jan 7, 2009 | 03:07 PM
  #35
Turbo Kyle's Avatar
Originally Posted by TTP Engineering
Sorry to hear about your car Kyle. Just read the signature.
Yea man, she is sitting balled up in the garage. Ill be lookin for an nice running IX in the spring
Also, the last post are on point. This clutch is more that easy to daily drive. I got used to it in one day. I only got chatter in reverse. Oh, and Scott hooked it up as usual. I bought 80% of my mods from him. Great support!
Old Jan 7, 2009 | 03:08 PM
  #36
Turbo Kyle's Avatar
A correctly adjusted clutch pedal helps too. Put it at the top!
Old Jan 7, 2009 | 05:22 PM
  #37
sikrsix's Avatar
When i got my unsprung my friend with a 450hp sti was looking into a clutch. He liked the way mine grabbed so called ACT directly and asked the diff between "sprung" vs "unsprung" (one has springs wasn't a tech answer. ) The answer he received -- "The sprung is supposed to be more forgiving, however they are identical in feel and the "sprung" clucthes seem to reject the springs and toss them out of the disc. --- Not something i want to happen to my clutch. Another friend with a turbo se-r has gone through 3 clutch discs. 1st sprung 6 puck - spline stripped out. (lasted a month) 2nd sprung 6 puck - Every spring came out of the disc. (lasted 2 months) 3rd unsprung Worked great and sold the car after 8 months of driving for a 240sx.
Seems like the sprung 6 pucks just add chatter unless you give it a little more throttle. My unsprung would stall if you didn't give it enough throttle. Id rather have the latter cuz I hate chatter! ( I used to rap)
Take that for what you will.
Old Jan 7, 2009 | 09:47 PM
  #38
TTP Engineering's Avatar
Thanks!
Old Jan 7, 2009 | 10:09 PM
  #39
Inprogress's Avatar
Originally Posted by nikkadanny
i have one, feels like stock to me now, but at first its grabby. oh and it does have lock out issues sometime..
You have lock-out issues too?
Old Jan 7, 2009 | 10:11 PM
  #40
Inprogress's Avatar
Originally Posted by evoIXcencal83
I ve had the HD-G6 sprung hub 6 puck in my car for about 6 months (about 7 thousand miles). I really like it so far. I havent had any lockout issues and it grabs really well. Its a bit more harsh than a full face disk but nothing that you cant get used to.
Did you adjust the clutch pedal?
Old Jan 7, 2009 | 10:21 PM
  #41
ssteve's Avatar
I have a HDSS pressure plate and a 6puck unsprung disc on a prolite flywheel. It feels great and I think its pretty easy to drive.. It does chatter a tiny bit at times but that doesnt bother me at all.
It does squeak a little bit on engagement, anyone else getting this?
Old Jan 8, 2009 | 07:43 AM
  #42
frost318's Avatar
I loved it when i first got it. but after about 3000 miles i had lock out issues with my 6 puck. Some people say they have lock out issues some dont. goodluck if you get the clutch.
Old Jan 8, 2009 | 08:13 AM
  #43
TIBOevo's Avatar
well going from stock to act hd pressure plate, act sprung 6 puck, and a act streetlight flywheel i noticed vibration in my clutch pedal. thought there was something wrong but after searching, i guess thats normal. i had to change my driving style to get comfortable with the new clutch. i like it for dd.
Old Jan 8, 2009 | 08:24 AM
  #44
ssteve's Avatar
Sprung or unsprung? I have only heard of one person with a unsprung 6puck getting lockout and after adjustment it went away.
Old Jan 8, 2009 | 09:27 AM
  #45
Turbo Kyle's Avatar
You do have to adjust the pedal as the clutch gets older. The clutch disk (if you have an organic) gets smaller/thinner and you have to adjust the pedal out more as it gets older. Same goes with a puck clutch. They get smaller and also bed into the flywheel so adjust it out more if you get lockout problems. I No lift shifted my car quite a bit with my Sprung 6 puck and HD pressure plate with no problems.
