Manley Turbo Tuff's vs. Crower's
Old Jan 7, 2009 | 02:36 PM
Chris@nolimitmotors's Avatar
Originally Posted by norcalSRTrida
they look like an awesome and very sturdy rod. any particular reason why you choose the manleys over crower?
thanks
We have seen crowers break before, i have never seen them break in a evo but have in some other cars.
Old Jan 7, 2009 | 02:44 PM
norcalSRTrida's Avatar
thanks for the headsup!
i couldnt find anything negative about the crowers nor tuff's on here.
where i came from (srt-4 scene), the crower's were considered the holy grail of all rods, w/ a distant 2nd to pauter, then eagle (that was all we had really).
jumping into the evo world, theres so many options... definately intrigued on going w/ the manleys tho at this point..
Old Jan 7, 2009 | 02:52 PM
dryad001's Avatar
i will def. check your build thread out. solo builds are FTW. nothing like buying/piecing and assembling a motor yourself and enjoying the **** out of it.
Thanks. And its A LOT cheaper than having BR, AMS, TT, etc shops build them for you. You'll know what I mean when you get done with just the short block, go back and check their prices when your done. I was about $1k cheaper than BR and close to $1700-2000 for an AMS block.
Old Jan 7, 2009 | 02:57 PM
03whitegsr's Avatar
RPM, torque, and detonation are the prime factors. detonation isnt an issue (im an extremely conservative tuner...low to mid 11afrs on race gas AND meth), and rpms wouldn't so much either (7500, w/ the occasionaly slightly higher shifts when necessary).
maybe im being just a lil too paranoid about using the standard ('economy' as some call it) rod bolts?
Just from my limited experience, detonation usually beats the **** out of the bearings first, leading to spun bearing and excess heat which leads to rod bolt and rod failure.
High power (torque) will usually bend a rod or destort the ends before causing all kinds of heat and eventual rod/bolt failure.
RPM tends to rip bolts and rods apart. These are the failures that usually show little signs of heat in the parts but catastrpohic failure. You don't get rod knock with these type of failures and is usually where a rod bolt failure happens.
Old Jan 7, 2009 | 03:09 PM
oh, i know 100% man. hell, i saved same as you, roughly 1700-2000 on my DIY build on my srt instead of going thru a vendor. hell, stroker kits for those cars are $7,000 thru the vendors there when i coulda got one mocked up by BC for 2700...
im not knocking vendors here selling shortblocks. i understand the need for the extra overhead costs...helping contribute to pay for r&d time, $ for shop cars, $ to pay the shop rent, etc. etc.
just tossing that amount of money around when a huge chunk can be saved isn't my idea of smart spendingand put towards something else.
Old Jan 7, 2009 | 03:58 PM
miragevo's Avatar
Veteran: Navy
Weights?
What are the weight differences vs. power handling between the Manley Turbo Tuff and Crower Rods?
walker992
Jan 3, 2017 11:50 AM
STM Tuned
Evo 'For Sale' Engine Internals and Drivetrain
Feb 8, 2016 06:33 AM
hutch959
Jan 27, 2016 06:06 PM
hutch959
Jan 5, 2016 06:00 PM
hutch959
Nov 28, 2015 06:35 PM
