Oil Stick pulls out
Old Jan 13, 2009 | 01:13 PM
esevo's Avatar
As much of you are correct, Im suprised only one of you mention checking compression and leak down...
If you see a increase of crank case pressure its mostly cause of piston ring failure.
Double check before you bandaid a real problem.
Good Luck
Evan Smith
Old Jan 13, 2009 | 01:15 PM
Ph3n1x's Avatar
Originally Posted by Evoryder
Keeps boost from being lost and entering the pcv system. And only allows a vacuum from the pcv. Supposedly better mileage, throttle response and power. I did notice the difference and I can pretty much feel anything major in my car...power loss /increase, timing being pulled etc...
Can u post a pic
Old Jan 13, 2009 | 01:36 PM
Ph3n1x's Avatar
Good Luck
Evan Smith
If it was as bad as that, then wouldn't you be blowing blue exhaust fumes?
Old Jan 13, 2009 | 02:01 PM
Creamo3's Avatar
I just installed mine yesterday (Map Crankcase vent) Car actually driving a little cleaner. I didn't remove anything just added to the existing connections. Install for the manifold side was a bidatch and required me to remove the upper strut due to my gorilla hands lol
Are you venting the front valve to the atmosphere or running it back to your intake pipe?
Old Jan 13, 2009 | 02:15 PM
esevo's Avatar
Not always, some times. Just depends how its leaking, where when how.
Old Jan 13, 2009 | 04:53 PM
Dapper Dan's Avatar
make sure your pcv valve is working and also doing a compression test wouldnt hurt just to be safe.
Old Jan 13, 2009 | 04:59 PM
leecavturbo's Avatar
when your running big boost you going to pressurise the crank case more than if you was on std boost. the more mileage you have will effect this more too as your leak down percentages increase with normal wear.
more venting is good
a spring is good (for saving messy bays)
resolve your blowby issue if its excessive.
evoryder have you any pics of the map vents installed?
Old Jan 13, 2009 | 05:28 PM
Evoryder's Avatar
Can u post a pic
WHen I get my hands on a digi cam. Maybe tomorrow. It's pretty straight forward.
Recirc back to intake. I have a catch can on the intake side, will be adding/upgrading to the saikomichi oil catch for pcv and intake side
Old Jan 17, 2009 | 02:19 PM
Evoryder's Avatar
Old Jan 19, 2009 | 12:07 PM
Ph3n1x's Avatar
thnks. So I still need a breather system though.
BTW WTF is that Air filter
Old Jan 19, 2009 | 04:47 PM
Evoryder's Avatar
Perrin Filter...one of the top flowing filters you can buy for the evo.
Old Jan 30, 2009 | 07:18 AM
SPANKED's Avatar
Good info!
kaj
Oct 17, 2015 05:51 PM
Fishd0
20
Feb 19, 2013 06:46 AM
Charlie87
Sep 13, 2012 09:00 PM
ImsoevoX
Oct 24, 2010 05:02 PM
chmodlf
Feb 28, 2010 08:25 AM
