problem holding boost
Old Jan 10, 2009 | 09:09 AM
evokid511's Avatar
hi guys sorry to bother you but i have a problem holding my boost and cant figure out why its not holding it... it will spike 25 and normally holds it but then all of a sudden it started dropping to 15 lbs... anyone can make a suggestion on why this would happen thank you
Old Jan 10, 2009 | 09:35 AM
chaotichoax's Avatar
boost leak test?
Old Jan 10, 2009 | 09:59 AM
evokid511's Avatar
not yet gonna have to i guess... no lines are losse or anything so idk
Old Jan 10, 2009 | 10:03 AM
Curt@MrLed's Avatar
Former Vendor
Bad boost controller, stuck wastegate, boost leak.
Old Jan 10, 2009 | 11:50 AM
evokid511's Avatar
boost controller is fine dont know about the wastegate, and how do i go about getting a boost leak check?? it was all fine before i went to the track yesterday and worked great at the track but after i left it started not holding the boost
Old Jan 10, 2009 | 11:57 AM
search for boost leak test or tester
Old Jan 10, 2009 | 12:00 PM
m4tt VIII's Avatar
boost leak test and i see you have an aftermarket intake but if you have the snorkel from the stock intake still on, check on those tabs
Old Jan 10, 2009 | 12:06 PM
evokid511's Avatar
i have an aftermarket k&n cone on the stock rubber piping and all the hoses are attached and look fine
Old Jan 10, 2009 | 01:12 PM
apagan01's Avatar
tharts fine budy, but you wont see a boost leak, you will barely hear it sometimes even doing a boost leak test.
it can be too many thinkgs most common, BOV, loose intercoolers pipes clamps, wastegate, do a boost leak test that will 95% of the time tell you whats wrong.
in my case i wasnt holding boost on top, changed stock diverter to a forge RS and hold 26 psi all the way to 7k believe it of not,,,,, but of course is Jesrtr tunned, he has some tricks to hold on top
Old Jan 10, 2009 | 01:22 PM
evokid511's Avatar
i guess i have to because i checked all the I/C piping and its on nice and tight, anf i have a type RS BOV figured maybe it was that so switched back to stock same thing though...
evokid511's Avatar
how do you go about getting a boost leak check???
Old Jan 10, 2009 | 01:35 PM
dorian7's Avatar
the easiest way is to get a pipe cap that matches the size of the inducer hole on your turbo (I think it is 2.5") you drill a hole in it (1/2" bit I believe) and then get a valve stem and put it through the hole you just drilled, make sure it fits tight. Then use either a coupling that you have on your intake or get something to allow you to seal it against the turbo. Then just pump the system up with air and listen!
