Evo won't idle. Any suggestions?
Old Jan 14, 2009 | 12:20 PM
SilverShadow03's Avatar
I have not received the used IAC yet. I hope to get it either today or tomorrow via snail mail. Once I do and install it, I will post the outcome in this thread.
Old Jan 14, 2009 | 07:32 PM
Murf's Avatar
I had a prpblem with my IAC a while ago..took one off a crashed evo..it did not fit and plunger was a diffrent design..So I took some spray cleaner and hosed the crap out of it dried it and did it again..don't forget to clean the area that the IAC goes into also..car idles fine now.
Old Jan 14, 2009 | 07:41 PM
What kind of spray cleaner did you use? Thanks for your input.
Old Jan 14, 2009 | 08:23 PM
humgaling12's Avatar
i had the same problem on my 03 evo.... i could not hold idle and i change the Idle Air Control.
Old Jan 15, 2009 | 05:32 PM
Problem Fixed. Refer to 1st Post.
Here is the used IAC installed and ready to start.
Old Jan 15, 2009 | 06:24 PM
Aby@MIL.SPEC's Avatar
I'm glad everything worked out
Old Jan 15, 2009 | 07:46 PM
So am I!
Thank you very much!!
Old Oct 28, 2009 | 06:00 PM
Well looks like I might be experiencing the same issue all over again after replacing the IAC in January, '09..
Please read my update on my first post for specifics..
Thanks!
Mike
Aby@MIL.SPEC
Mar 9, 2021 11:41 AM
evo8.03
Dec 24, 2020 09:33 PM
Boombox
32
Jan 23, 2016 02:34 AM
Aby@MIL.SPEC
Feb 15, 2009 12:30 PM
