Compression test cold and warm egine: differences
Old Jan 12, 2009 | 05:48 AM
DimitrisIX's Avatar
I just did a compression test on my relatively new build. It came out 100 psi across all cylinders but the engine was cold.
Has anyone tried it on a cold engine, then warm it up and check again. How much difference can the engine temp make?
thanks
Old Jan 12, 2009 | 05:50 AM
SloRice's Avatar
or just warm the motor up.....
cold compression tests are useless.
Old Jan 12, 2009 | 05:53 AM
DimitrisIX's Avatar
I just installed my BR COP i cant bother to remove it :-) i know that the engine should be ok because they are all 100 i just wanted to know how much difference can engine temp make. I searched and found posts reporting 140 psi warm on a IX. So by warming up the engine you can get 40 psi more? it seems weird to me but I am not a mechanic.
Old Jan 12, 2009 | 06:09 AM
SloRice's Avatar
There is no formula that says it will be xxx psi when cold and yyy psi when warm.
As for the 40psi increase you said from the motor being warm. When metal gets warm, it expands, thus tightening all the clearances in the motor. That's how it creates more pressure. Simple physics.
Old Jan 12, 2009 | 06:39 AM
JakeTheVIII's Avatar
Like he said, your test was useless. If you ever re-do it with a warm motor, that will give you a real measurement.
Old Feb 5, 2009 | 11:01 AM
CNano8's Avatar
Dont mean to bring back a thread from the dead but how would you go about compression testing a motor thats out of the car already? Like if you were to buy a second longblock off someone.
Old Feb 6, 2009 | 03:16 PM
IMPdemon's Avatar
FWIW I got close to 180 across all cylinders when I was doing a pre-buy last spring on my 8, and that was ice cold.
For testing a block out of a car, doesn't the starter motor stay w/the block? I would hook that up to 12 V and crank away.
Poopy
Mar 16, 2014 03:31 PM
graphitegrey9
17
Feb 3, 2012 10:14 PM
04EBevo
12
Mar 14, 2011 07:19 PM
xtremeIX
Nov 28, 2010 04:07 PM
snafufx
Aug 7, 2010 11:14 AM
