question on oil filter
Old Jan 12, 2009 | 12:19 PM
silver_03_evo's Avatar
ok so i changed my oil yesterday and everywhere i go they tell me the fram part # is 7317 but this is like a shot glass compared to the one i took off, so if anyone else has had this issue what filter # did you use instead of the 7317
Old Jan 12, 2009 | 02:01 PM
barneyb's Avatar
First of all, I suggest using something besides a Fram. Pick any other brand and you will be getting a better filter.
Second, I suggest digging back into the filter book until you find the Dodge Stealth - back before the year 2000 and using that filter. It is the largest filter that will fit an Evo, Then when you buy the 5 quart container of synthetic oil you dump the works in - simple.
Old Jan 12, 2009 | 04:10 PM
yeah i would of used the mobile 1 one but they didnt have it and thank you for the info
Old Jan 12, 2009 | 05:10 PM
travman's Avatar
Buy oem filters - they are the best and under $5.00 a piece, order 3 at a time and you will always have them available.
ditch the fram crap +1......and yea most parts stores try and sell you the tiny lancer filter, that is all that is in their computers - you have to look it up in the book.
Old Jan 12, 2009 | 08:12 PM
Evo8Emperor's Avatar
just curious but your sure that its any stealth before 2000 ? does turbo or non turbo matter ?
Old Jan 12, 2009 | 08:17 PM
LancerEVA06's Avatar
If you really want to go with fram: PH9688. ~$8 at AutoZone and it's made by either Denso or Purolator (PureONE).
Old Jan 12, 2009 | 08:26 PM
thank you everyone for the help
Old Jan 13, 2009 | 10:07 AM
barneyb's Avatar
As I recall, they both use the same filter.
A little story: In midyear in 1992 the Mitsubishi DSM 4G63 engines went from a larger filter to a smaller filter. So when you went to pick up a filter from the parts house the book wanted to know exactly when your car was built.
Well, this caused a lot of confusion amongst owners. So there were constant posts to the boards concerning which filter to use. To make it even more confusing my car came with a large filter and the filter book, even when I went by the correct build date, specified the small filter.
Finally, some inquiring mind went all the way to the Mitsu engineers to get this question cleared up. First he learned that Mitsu specified the smaller filter because they had intended to put something on the car that would intrude into the oil filter space. Well, this never happened. Second, they said that any filter specified for ANY Mitsubishi engine will fit any other Mitsubishi engine. They all use the same diameter gasket.
So what you want is a quality filter with a good strong bypass valve and lots of media area. Plugged filter media is what causes the bypass to open and this leads to noisy lifters. Well, the Stealth has a Mitsu engine, the filter is a lot bigger and, guess what, it is cheaper than the Evo filter. I even run one on my WRX.
jono119
Outlander Sport
Mar 24, 2016 05:02 PM
jimbo74
Lancer Engine Tech
Jun 18, 2014 03:28 AM
dondi0210
Outlander Sport
26
Jul 4, 2013 09:06 PM
SOCALMITSU.COM
Huntington Beach/South Coast/Long Beach/Victorville Mitsubishi - CA
Oct 1, 2009 06:06 AM
Blacksheepdj
Lancer How Tos / Installations
Nov 23, 2007 09:26 AM
