porting ?
Old Jan 17, 2009 | 10:30 AM
ch53avitech's Avatar
porting ?
I bought a used ported exhaust manifold from a member on here. I was just wondering how can I tell if it was ported or not? The manifold, like I said, is used and the runners aren't very clean on the inside. I believe what the seller told me, I'm just wondering.
Old Jan 17, 2009 | 11:02 AM
Jay644's Avatar
Maybe get some carb cleaner, spray and clean out the runners then see if they are smooth. Just a thought.
Old Jan 17, 2009 | 01:47 PM
Steve93Talon's Avatar
Hold the outlet gasket up to the flange, if the holes on the manifold are the same size as the gasket it's ported.
Old Jan 17, 2009 | 02:02 PM
jmelocik's Avatar
Measure a stock manifold and then the one you have and compare the numbers. Not everyone who ports manifolds does a gasket match. Since the ports on a stock head are smaller than the gasket, it would actually rob power if you gasket match and mount it to a stock, unported head. If you need a stock one to measure I am in NC and can lend you a hand.
Josh
Old Jan 17, 2009 | 03:03 PM
Notice I said "outlet flange", meaning the turbo to manifold side, not the head side. If you're not gasket matching the outlet, there's no point.
z32cctx
Nov 26, 2011 11:38 AM
CtSilver03Evo
25
Sep 28, 2011 07:31 AM
anthonyrb98
Aug 7, 2011 10:06 AM
EVO196
Sep 25, 2010 02:38 AM
BlackonBlack2
10
Oct 24, 2008 09:57 PM
