Battery in trunk
Old Jan 21, 2009 | 12:11 PM
antilag_200's Avatar
Every box, that I could find, including the Morosso one was too big so I decided to make my own,and powdercoated it for looks. it holds a full size yellow top and is vented
Old Jan 21, 2009 | 10:18 PM
motoxxx55's Avatar
Mine is customized by the audio shop... ...happy with it & so far so good
Old Jan 22, 2009 | 08:27 AM
Evoryder's Avatar
^ you should get a box for it.
Old Jan 22, 2009 | 08:39 AM
BluEVOIX's Avatar
Why is getting a box soo important when relocating the battery to the rear?
Old Jan 22, 2009 | 12:11 PM
sho669's Avatar
Originally Posted by evane
i've been thinking about putting my battery in the trunk...but isn't if you have a battery in the trunk you can't run at the drag strip, no matter your ET time, unless you have a cut off switch mounted on the rear bumper?
yes that is a NHRA rule, rear mounted batteries require a cu-toff switch at any E.T.
Old Jan 22, 2009 | 12:15 PM
sho669's Avatar
It's not important as long as you use a dry cell type battery (optima, ect.)...looks nicer, much cleaner install, as long as you don't have a thing for throwing large metal objects in your trunk you should be good!
Old Jan 22, 2009 | 12:16 PM
Dragracer187's Avatar
Is it safe to have a big tank of meth and a battery in the trunk?
Old Jan 22, 2009 | 12:28 PM
projectevo9's Avatar
Originally Posted by Ted B
I've never understood the mini battery idea. All it does is attempt to resolve a problem by potentially creating another problem.
The best solution is to get the battery out of the engine compartment completely. Shifting the weight of the battery from front to rear is beneficial to the weight distribution of the car, and represents a net shift of 2X the weight of the battery. Not to mention, it creates the most additional space in the engine compartment, and you won't be saddled with a puny battery that is undersized for the application.
[IMG][/IMG]
I like this a lot. I see you're using stock battery tray and tie down. What other parts did you use and how much did you spend? I'm very interested. Thank you.
Old Jan 22, 2009 | 12:29 PM
Sharkbite2000's Avatar
Get a moroso battery box your better off
Old Jan 22, 2009 | 01:27 PM
_ronin_'s Avatar
Originally Posted by chaotichoax
Me too. I can post up some pictures if you need help or want ideas.
Old Jan 22, 2009 | 01:33 PM
SME's Avatar
SME
Mines in the trunk, spent about $15 thats it. No box for it.
Old Jan 22, 2009 | 02:01 PM
BluEVOIX's Avatar
How is yours held down? Parts purchased list? Pics?
Old Jan 22, 2009 | 02:17 PM
edardnaekim's Avatar
Excuss the dirty trunk
Old Jan 22, 2009 | 02:54 PM
Joemflsxe's Avatar
Anyone have any install tutorials, I searched and couldn't find anything.
Old Jan 22, 2009 | 02:58 PM
RLLN247's Avatar
Does anyone have any pics on how their hooking up the cables in the front of the car ? Are you using some type of block thats mounted or just rapping it up with electrical tape. Tastefully done pics please!
