Help! Advice needed!!
Old Jan 21, 2009 | 03:31 PM
NYREDEVO's Avatar
Ok guys...I really need some opinions on how to handle this situation. Let me start from the beginning.
June - Car started stuttering, fouled #4 spark plug - went to Mitsu, they changed wires,plugs boot etc.
November - Sick of Mitsu, found new shop ICS because I went there to have car re-tune after Mitsu wiped out flash. Car retuned, still down on power. Stuttering came back. ICS replaced coils, wire, plugs and re-tapped plug hole #4 b/c it was stripped.
Dec - car ran ok, stuttering & fouling plugs came back again. ICS replaced BOV, did some work on exhaust, other minor fixes.
Dec/Jan - 2 weeks later - car starts SPEWING white smoke - towed up to ICS. Piston #4 Finished - cracked right in half. Replaced the following - Valve job, pistons, rings, rods, head gasket and added cams. (at that point why not?)
Couple of days ago - got car back, running great for 4 days....oil light comes on and it starts stalling when coming to stop or at low RPMS. Once I give gas, oil light comes off. I take it back to ICS - he says - oil pump and main bearing shot, needs to replace - also need to boil block (to clean any frags of piston out), repair crank and balance shaft bearing.
At this point, I've had enough with this F#@kin car. Total spent - close to $10K, plus another $3200 if I do everything he's recommending. What do you guys think? Do it? Or fix the oil pump/bearing and hope the engine don't sh$% the bed?
One more fun fact - car has 115K on it!
Old Jan 21, 2009 | 04:40 PM
gsrboi80's Avatar
I probably would have just done the shorty and front cover the first time.
Don't get discouraged. Do you have another car??? If so park the EVO for a while. You'll start to miss her and get motivated to get her running again. Save and build her right.
Get a Bushur, Jam, AMS shorty a new front cover assembly and timing components and drop her in
Old Feb 23, 2009 | 08:21 AM
gonungeter's Avatar
ok i think my car might be starting to do the same thing but im not sure. whenever you changed your plugs did the ses light go off? everytime i hit 5grand mine comes back on and nobody can figure it out. was yours kind of like this?
NY Evo
Mar 13, 2013 05:20 PM
iggypooper
Aug 2, 2012 10:31 AM
06mr775
Jul 13, 2012 09:48 AM
CalebL
22
May 15, 2008 04:50 PM
EVLVD 8X
Apr 28, 2006 11:33 AM
