HELP: Stock turbo clamp
I have a 20g-9-5 which uses the stock clamp (not sure what the name of it is?) that holds the compressor housing to the hotside but anyways the screw holding them together is very rusted. I wanted to know if anybody else has had this problem and if this screw broke the turbo would be toast correct? I bought this turbo from somebody a while ago so i dont know if its the stock screw or not. Should i replace this screw before my turbos splits in half? Is it possible to change this screw without taking the whole thing apart? Thanks for your input
You do not want it to break while driving! Just take the screw and bolt off and go to the nearest parts store and get a new one. You can take the bolt off without the compressor and hotside seperating. It usually takes a screw driver or something to pry them apart. If you need the whole part assembly i actually have one in my stock for sale thread.
https://www.evolutionm.net/forums/sa...evo-parts.html
adrock1559
Evo X How Tos / Installations
Jun 12, 2008 02:43 PM
