Evo 9 Block Evo 8 Head
Old Jan 22, 2009 | 12:26 PM
Stradag's Avatar
Lightbulb Evo 9 Block Evo 8 Head
Ok I blew my Evo 8 motor and I purchased a Evo 9 block. I have done searches on here for two days and cannot find any info on this topic that is 100%. According to who ever I talked to at buschur racing the "passages" are differrent I dont know what poassages he was talking about, but Ron begs to differ, So I called RS motors where I purchased the evo 9 block and Ron says that all I have to do is block off the oil passage (Mivec oil supply) on the rear of the block and move my oil pressure sending unit sensor to the oil filter houseing. Luckly I have a sandwich adapter with a free port so in theory I should be fine. I get the block next week, so I will update when I find out for sure, that way the next person that tries to do this swap doesnt have such a hassle finding out if it will work.
Mike
Old Jan 23, 2009 | 09:15 AM
Stradag's Avatar
I was trying to find some info about the differences between the evo 8 block and the evo 9 block, I found this on tristatetuners.com ------>>> A five-layer metal head gasket design with revised coolant passage holes replaces the three-layer metal unit to better withstand the engine’s elevated, forced induction fed cylinder pressures. The pistons in the Lancer Evolution are made of a stronger alloy and are sealed to the cylinder wall using a more efficient two-piece ring package, replacing the previous three-piece ringset. This revised ring arrangement helps reduce the engine’s oil consumption by 10 percent.<<<<------ has anyone ever heard of this info before?? It says revised coolant passages on the head gasket? but I have read forums here saying that people have used 8 blocks with 9 cylinder head, so the cooland passeges must be in the same location on both blocks right? also no matter where I look for head gaskets they all say 2003-2006 lancer evolution, it seems both models of the evo use the same head gasket?
Mike
http://www.edmunds.com/insideline/do...ticleId=105130
I found this article on edmunds that confirms different oil rings ^^^^
Old Jan 23, 2009 | 05:07 PM
justboosted02's Avatar
it works 100%
i have an evo 9 block and an evo 8 head and i use an evo 8 HG. match the HG to the head
Old Jan 23, 2009 | 10:06 PM
Stradag's Avatar
Originally Posted by justboosted02
it works 100%
Wow Thats a relief my block is supposed to be here tuesday. Did you do the install? Did you have to put the oil pressure sending unit on the oil filter houseing?? Thanks for the reply by the way, much relief
Mike
Old Jan 24, 2009 | 12:05 PM
Mike
yes i did the install. rather than putting the oil pressure sensor on the oil filter housing I simply found a metal bushing to adapt the larger hole on the block to the thread of the oil pressure sensor
Old Jan 24, 2009 | 10:12 PM
Stradag's Avatar
Thanks alot man very helpful, I am going to take pics of the hole and ill prob do the converter bushing too and post them just for ref. for others trying to do the same. Thanks again
Mike
Old Feb 7, 2009 | 07:12 AM
Stradag's Avatar
The metal bushing is kind of difficult to find so heres a link to the site where I purchased mine>>>> M12x1.25(M) - LMA086
Mike
Old Feb 16, 2009 | 05:41 AM
Stradag's Avatar
Exclamation
Mike
So I just got the bushing adapter in the mail, put some teflon tape on it screwed it into the block, perfect fit. All though I tried to tighten it with a wrench and the threads snapped off in the block, luckly they came out easy. I am going to try to find a tap and die for 1/8" NPT and make my own out of a m12x1.25 drain plug I got at ace hardware, I will keep you updated.
Mike
Old Mar 4, 2010 | 06:40 PM
hawaiievo's Avatar
so you just used the oil passage for the mivec and hooked up the oil pressure sensor with an adapter?
I'm going to be doing this also in the coming weeks. any updates??
Old Mar 4, 2010 | 08:03 PM
Stradag's Avatar
i ended up just hooking up the oil pressure sending unit to the oil filter housing theres a how to on here.....the adapter I got broke as soon as I tried to tighten it....if you can find a steel adapter it will work perfect
Old Mar 5, 2010 | 04:36 AM
hawaiievo's Avatar
ok i'll find it. What did you use to block off the mivec oil passage, just a plug? size?
thanks
Old Mar 6, 2010 | 07:23 AM
Stradag's Avatar
It uses a drain plug m12x1.25 make sure you use a metal crush washer on it or it will leak, another option would be to attach a line to that hole and route it to a vacuum distrbution block and run you oil pressure sending unit to that. I was goin to do that because i have a oil sending unit for my hks gauges too.
Old Mar 30, 2010 | 03:16 PM
InDub's Avatar
Im doing this right now... Engine is ready to go in the car.
Im going to try and drill a steel dran plug and weld an 1/8" NPT female to it to make it work
Old Mar 30, 2010 | 04:53 PM
FYI, AMS just came out with an adapter to use the oil pressure sensor in the stock 8 location when using a 9 block
Old Mar 30, 2010 | 05:38 PM
InDub's Avatar
Nice! Do you know if they have it in stock?
