another boost leak question
Old Jan 23, 2009 | 09:07 PM
evokid511's Avatar
im not sure whats involved in that but probably could do it... whats that mean though like what is wrong there t need to do that??
Old Jan 23, 2009 | 09:08 PM
sparky's Avatar
Originally Posted by bbyevo8u
??? what does that do for him ???
The OP tried it and he creeps to 20# from 15#. So, if he adds another 4-5 PSI of preload on top of the 15#, I think that he should peak at 19-20# on the wastegate and creep to 24-25#, which is his target boost level anyway. If however it were to hold at 19-20# and not creep, then he could just add the 5 PSI with the MBC.
EDIT: One thing at a time. First we'll try to solve the extreme taper swing down to 15 PSI. If it still looks to creep, that would be another, separate issue.
Old Jan 23, 2009 | 09:15 PM
evokid511's Avatar
still a little lost here, does that mean my wastegate spring is bad and not holding the boost anymore or what?
Old Jan 23, 2009 | 09:32 PM
sparky's Avatar
I think that your wastegate is mechanically sound. The weather may be causing things to act up. Has it been colder lately? Have ambient air temps been fluctuating? Is it colder now than when your car was tuned?
EDIT: The IX turbos are notorious for tapering and the colder weather will tend to cause the turbo to creep.
Old Jan 23, 2009 | 09:47 PM
evokid511's Avatar
ummmm no been about the same as when i got it tuned
Old Jan 24, 2009 | 08:03 AM
evokid511's Avatar
well with the controller turned all the way down it hits 15 then creeps to 20
rartist
16
Sep 6, 2010 12:33 PM
Carter19
11
Apr 30, 2010 08:32 PM
BCOZEVO
Aug 10, 2008 10:10 AM
BEN06'
17
May 20, 2007 05:20 PM
Jin4g63
14
Sep 29, 2005 06:35 PM
