what caused this to blow out???
Old Jan 26, 2009 | 06:45 AM
Mr. Evo IX's Avatar
Why did you replace the head gasket last time? Just because it's running low boost doesnt mean it can't lift the head. The head / block surface may not be flat and you didnt get a good seal when you replaced the head gasket.
Old Jan 26, 2009 | 06:48 AM
hotrod2448's Avatar
Sounds like it could be a side effect of what ever caused you to change the head gasket the first time. If it pressurized the coolant system then it could have loosened the freeze plug and just taken a little while for it to pop out.
Old Jan 26, 2009 | 07:51 AM
justboosted02's Avatar
Originally Posted by mr 2.3 evo
to be honest yea.... about 2-3 weeks ago i just replaced the head gasket so ya i had to refill the coolent
where you sure to burp the coolant system? you might have had a air bubble in your system still
Old Jan 26, 2009 | 05:58 PM
mr 2.3 evo's Avatar
i replaced the gasket last time due to lifting the head on stock head studs. so once that happened i put arp's in and a new gasket
Old Jan 26, 2009 | 06:04 PM
mr 2.3 evo's Avatar
I did not "burp" the system but once it was I was finished with the install I filled the system to the top and started car till operating temp so the thermostat open and then added the necessary coolant to top it off
Old Jan 26, 2009 | 07:57 PM
you had an air bubble in your system that flashed and popped out your freeze plug, i did the same thing when i first finished my build and i popped a freeze plug after a week of driving, luckily it was one on the front of the block and i caught it immediately. I replaced the freeze plug and filled with coolant and burped the system, have not had a problem for 4k miles now.
in order to correctly fill the coolant system you have to jack the front of the car up, and buy a coolant filler funnel that sits where the coolant cap goes and you can fill untill the coolant stops bubbling up. then you know youve gotten all the air out
good luck with your rebuild
Old Jan 26, 2009 | 09:28 PM
Dapper Dan's Avatar
Originally Posted by jmelocik
Temps where normal? Sounds like the brass plug was not pressed in properly and finally let go.
Josh
you probably blew your HG and pressurized the coolant passages, and when the freeze plug popped out it broke your timing belt.
that sucks, im sorry to see that
im gonna have to agree with these posts.
Old Jan 26, 2009 | 09:36 PM
Aby@MIL.SPEC's Avatar
why did you have to change ur headgasket?
Old Jan 27, 2009 | 01:31 AM
mr 2.3 evo's Avatar
had stock headstuds in befor and lifted the head.....
Old Jan 27, 2009 | 01:34 AM
mr 2.3 evo's Avatar
thanks a lot. I have come to the conclusion that’s prolly what it was also just a missed air pocket in the system. I also appreciate all your help and info
Old Jan 27, 2009 | 03:39 AM
vboy425's Avatar
if you're head got lifted, chances you head is warp, sometime you can't see it. the only way to find out is to take the head to machine shop and have it checkout and deck.
Old Jan 27, 2009 | 05:53 AM
mr 2.3 evo's Avatar
Originally Posted by vboy425
if you're head is lift, chances you head is warp, sometime you can't see it. the only way to find out is to take the head to machine shop and have it checkout and deck.
did that already everything check out fine. thats what makes me belive it was a air pocket in the cooling system
Old Jan 29, 2009 | 02:57 PM
Mr. Evo IX's Avatar
Interesting, I didnt know this. So just running it with the cap off until the bubbling stops wont completely fill the coolant system?
