Really Bad News:(
Old Jan 27, 2009 | 06:14 AM
Mad_SB's Avatar
Originally Posted by zeus1
think i would need bigger injectors? running 680's now on pump
Probably so, the fuel demand will go up with a 2.3 and if you go red in the future you will most certainly need bigger.
I hate to say it man but you may be deeper in the hole than you think. If the motor lunched itself, be prepared to replace the turbo and the head. I hope you don't need too, but there is a chance some inside bits made it to the outside via the exhaust path, which includes the turbine wheel. Also a chace that the valves introduced themselves to the pistons on one or more cylinders
Old Jan 27, 2009 | 06:49 AM
zeus1's Avatar
yeah i will have to wait and see what the results of the teardown are. i am prepared for the worse though
Old Jan 27, 2009 | 07:02 AM
tkklemann's Avatar
How about a high compression 2.3?
That might turn out to be an interesting motor. Maybe a 10:1?
Old Jan 27, 2009 | 07:13 AM
SME's Avatar
SME
Damn that blows man let us know what happened when you find out!
Old Jan 27, 2009 | 08:10 AM
Ph3n1x's Avatar
So you don't know what happened and your out engine shopping? Get the cause before you jump to conclusions.
Old Jan 27, 2009 | 08:54 AM
zeus1's Avatar
well it looks really bad. i am going to get the cause tomorrow or the next day but just getting some ideas in case its the worst case scenario.
Old Jan 27, 2009 | 09:51 AM
ExViTermini's Avatar
Sounds like a rod bolt failed, common link in these motors. Mine did it many moons ago, a friend of mines fpgreen/alky car did it less than 2 weeks ago.
When mine went the turbo ended up being ok, clipped a wheel or two but it worked fine. Fubared the head for the most part...and of course the whole shortblock is unusable scrap.
Old Jan 27, 2009 | 04:09 PM
Excalibur's Avatar
How common? I'm debating buying an evo and am looking for info.
Old Jan 27, 2009 | 11:26 PM
zeus1's Avatar
update. cylinder one..rod blew through the block. more info tom
Old Jan 27, 2009 | 11:32 PM
NJ_EveOhVIII's Avatar
wow man that really blows but look what your going to get out if it really interested in the route you choose im in the same pickle deciding what motor to go with 2.3 or 2.0
Old Jan 27, 2009 | 11:34 PM
markymark1082's Avatar
Have you thought about a 2.2?
Old Jan 28, 2009 | 04:54 AM
zeus1's Avatar
there seem to be many options. i need to i figure out what is "reasonable" to spend on the car at this point. i think i am leaning towards a 2.0 again though. as it was plenty powerful for my tastes plus i wont have to get bigger injectors, re-tune the car etc...
Old Jan 28, 2009 | 05:34 AM
EVO8LTW's Avatar
Just curious how high you revved the car on WOT pulls? I know it let go in normal driving...
Old Jan 28, 2009 | 05:38 AM
Craig King's Avatar
With all of these recommendations for a 2.3, what does a 2.3 $$$ go for now anyways?
Old Jan 28, 2009 | 05:40 AM
apagan01's Avatar
Originally Posted by DynoFlash
I agree the Buschur 2.3L is one amazing motor - the best you can get
Hopefully its just an oil leak and you can fix it
i was going to say,,,, dip stick poped as long as you shut the car quick it should be ok, unless you drove it while it was dry
GL
