fuel system for 800hpevo
Old Jan 28, 2009 | 10:49 PM
precisionpsi9's Avatar
im doing a fuel system for a customer and was thinking about doing the full
blown double fuel pump setup. im goin to run -8 to a fuel lab fuel filter then to
a ams race fuel rail. Then to a -6 return system though a fuel lab regulator
on 1200 precision injectors.
i would like to make about 600hp on 93pump gas
and make 700 to 800hp Q16. What do u guys think should i run a bigger feed
line like -10an.
Old Jan 28, 2009 | 11:20 PM
Fusionworks's Avatar
I have a very similar system on a GSX also using the full blown dual walbro in tank adapter except I have a 10-8 setup. Power levels are about what you are wanting running a BW S372 turbo. An 8-6 system should theoretically barely flow enough fuel...but why err towards the small side?
Old Jan 29, 2009 | 01:18 AM
boostinmarc4's Avatar
For what you are looking to do I'd probably go -10 -8, its safer and shouldn't change the cost much. Better to go to big than too small and have to redo it...
Old Jan 29, 2009 | 05:05 PM
k guys thanks for the input ill do the-10 n -8
Old Jan 29, 2009 | 06:53 PM
staatz's Avatar
my 1200s are maxed out at 730+ on c16/meth
Old Jan 30, 2009 | 07:28 PM
i really dont want to go bigger then 1200cc on a street car.
Old Jan 30, 2009 | 07:32 PM
David Buschur's Avatar
Our double pumper will do that no problem, on the stock lines with the stock regulator actually. You'll need to only change to an aftermarket fuel rail. I'm running 1200 cc injectors in my car and it put down 705 whp on our dyno today, it's gone 9.04 at 159.64 mph, weighs 2985 pounds with driver. You are looking at less than $700 plus the price of your injectors.
Chu's Mom
Mar 19, 2017 08:40 AM
Exyia
May 2, 2016 09:27 AM
theblackbeast11
Mar 14, 2016 06:55 AM
Whoop_ass
26
Sep 30, 2009 04:04 AM
