Where can I get an OBD-II diagnostic tool?
Old Sep 16, 2003 | 08:16 AM
EV0lut10n_8's Avatar
My "Service Engine Soon" light came on last night. I want to see whats up but i don't want to go to mitsu....can anyone help?
Old Sep 16, 2003 | 08:24 AM
Trustz's Avatar
I got my OBD II scanner from ebay for about $125, it read the code number and erase the code(turn off the CEL lights), just search with " Innova", you can take a look the auction.
Trustz
Old Sep 16, 2003 | 08:27 AM
enkei1's Avatar
i bought snap on for 300 on ebay,works great, reads, clears and saves codes
Old Sep 16, 2003 | 09:01 AM
Guru_Del's Avatar
go to autozone they will pull the code for free. or get the autotap from www.autotap.com and it hooks to a laptop or palm pilot
Old Sep 16, 2003 | 09:16 AM
992gnt's Avatar
www.pocketlogger.com
Old Sep 16, 2003 | 10:29 AM
freedom's Avatar
Re: Where can I get an OBD-II diagnostic tool?
Many of the autoparts chains will loan the scan tool for zero cost. In your case drive over the Arlington Heights Road and Golf (58) and Murray's will take care of you. (Note that they hold the cost of the tool on your credit card in case you run off with the scan tool. Refund'ed to the card when you bring the tool back.)
Works for me.....
Old Sep 16, 2003 | 10:31 AM
freedom's Avatar
Are you telling me that the XEDE is causing a check engine condition!!!
Tell me it isn't so!
What else is on the engine at this time?
Old Sep 16, 2003 | 12:19 PM
i dunno yet...that is why i want to get a diagnostic tool....tonight i am going to go over the xede install and go to autozone and borrow the tool....and see what code pops up...i will let you know..
Old Sep 17, 2003 | 08:46 AM
ok i got the P0300 code for random engine misfire....
i reset it and it hasn't come back...although my car is stuttering in idle a lil.....i am going to make a grounding kit this weekend hopefully that will help...
i also changed my oil recently and over filled it a tad...still haven't had time to syphen the excess out....i don't think that could contribute to a misfire though
i definetly think that the grounding kit will help...i think it is essential first step to adding any mods....especially electrical ones...
Old Sep 17, 2003 | 03:26 PM
freedom's Avatar
So far I'm not convinced that the grounding kit concept has any validity. What I tried was temp connection of monster cable between the negative side of the battery and the coils / head / intake manifold. Basically I found zero improvement.
The sensors have their own ground so I wouldn't expect anything. The coils do rely on the ground path.
Overall my take on this is that on a old car with bad grounds, a grounding system could potentially help. On a new car this concept is simply junk science. I don't design or architecture automobile electrical systems for a living but I do have more than one degree in electrical engineering.
When I have had misfire problems it has always been traced to bad gas. Try switching stations and gas. Also Techron injector cleaner is not a bad option.
With respect to gas the last time (P300) was with some off brand gas (no... not the Evo). Right now I'm using BP in both of my cars with zero problems.
Old Sep 18, 2003 | 08:35 AM
I normally go with shell mobil or BP but your right it could have been bad gas....i reset the code and it hasn't come back...although i am on the same tank of gas still... for 40 bucks though i am going to do a little test of my own for a grounding kit...to see if it helps anything...smooth out my engine idle a tad...it will give me something to do this weekend anyway...i will let you know though
Old Sep 18, 2003 | 09:57 AM
xtnct's Avatar
Did anyone try this $50 code reader??
http://www.harborfreight.com/cpi/cta...emnumber=46030
Old Sep 18, 2003 | 11:43 AM
freedom's Avatar
I'm willing to change my mind on the ground thing ....
JDM EVO 6
AEM EMS
Jan 3, 2016 01:33 PM
EvoIIIAj
Oct 26, 2012 04:45 AM
Kevin Knight
11
Mar 13, 2010 08:31 PM
davelancer
Canadian Forum
Jul 21, 2006 06:00 AM
unknown2
11
Mar 6, 2005 10:40 AM
