Royal Purple 75W90
Old Jan 30, 2009 | 08:13 PM
Blast83's Avatar
Royal Purple 75W90
So I was looking for Redline MT90 for my tranny refill for tomorrow and couldn't find it at any of the local stores. I found Royal Purple ($15/quart ) 75W90. Will this be ok? I know people love his oil and $45 for a tranny fluid isn't too bad if it will last 2 years/30K miles.
Is MT90 just a GL4 spec 75W90?
Old Jan 30, 2009 | 08:19 PM
apagan01's Avatar
AMSOIL MTG GL4 100% synthetic keeps everything inside clean
It is formulated specifically for maximum protection in the most demanding manual transmission and transaxle applications where an extreme pressure GL-4 gear lube is specified, including those where high horsepower/high torque engines and towing or heavy loads increase transmission stress.
Old Jan 30, 2009 | 08:20 PM
jlaznlover's Avatar
i'm using the RP 75W90 in the tranny. at a cold start up, shifting is much more notchy then oem. gears grind slightly if you shift too fast when the tranny isn't up to operating temps. when it does fully warm up, it a little bit smoother than oem. i'm probably going with a different fluid when i hit 60k
Old Jan 30, 2009 | 08:34 PM
Blast83's Avatar
Well that's lame. It feels like my shifter is catching the gears randomly right now. I have 29K miles on it, so hopefully it makes it somewhat better. Either way, it's time to replace it. Got a freak heat wave (45F) for tomorrow, so no time like the present.
marinejensen
12
Oct 4, 2009 05:10 AM
Sideck
Aug 8, 2009 08:58 PM
Appauldd
48
Mar 20, 2009 08:07 PM
RalliArtEvoVIII
13
Apr 27, 2005 06:34 AM
Kwman
Mar 16, 2005 03:26 PM
