Wrapping Full Race Headers?
Old Jan 31, 2009 | 11:31 PM
sdfontanini's Avatar
Would u guys recomend wrapping my full race headers? they already have the ceramic coating, but it's flaking in a few areas. would painting them w a high temp paint hurt them?
Old Feb 1, 2009 | 07:12 AM
cij911's Avatar
I would definitely recommend wrapping the headers / exhaust manifold (very common in race applications)...Although I have not coated and wrapped (just wrapped) the Evos manifold, I have with Porsches. (I would not waste the time prepping and painting the areas where the coating has flaked off and just wrap.) Good luck...
You may want to take some logs before and after to see if you gain anything...
Old Feb 1, 2009 | 08:26 AM
Cyloc's Avatar
It is always a good idea to wrap tubular headers. There are many benefits to it. One of the biggest being the reduced heat in the engine bay. By reducing the heat in the engine bay you can lower the temp of the air that is coming into the intake. This can also help the car make more power, since the air well be cooler and more dense after it exits the intercooler. It also allows less heat affects on the fluids to the various other parts of the car. I have seen engine bay temps get so hot that the brake fluid is at boiling temps. The reduced heat can help preserve the fluids.
The only down side is that wrapping the manifold can hide cracks. Also, depending on your worries about weight, you can add about 3 to 5 pounds to the car.
Old Feb 1, 2009 | 09:10 AM
justboosted02's Avatar
just make sure that wrapping the headers does not void full-race's warranty
Old Feb 1, 2009 | 12:47 PM
mazdadike's Avatar
let us know if there is any noticable power gains
Old Feb 1, 2009 | 12:51 PM
Well i haven,t installed them yet but i think i will go ahead and wrap them. is there a good how to, on doing this. is there a good brand of wrap that i should be using?
Old Feb 2, 2009 | 08:57 AM
What header wrap do you guys suggest? I just hope this doesn't mess up my Full Race Headers
Old Feb 2, 2009 | 09:07 AM
r.m.s.'s Avatar
Call fullrace buddy to verify that it won't void there work on either or both the coating and welding. And maybe ask them what wrap they reccomend.
Old Feb 2, 2009 | 12:48 PM
I've decided that I'm just going to spray them with a high temp resistant paint. Black VHT paint is what I'll be going with. Hope it holds up.
Old Feb 2, 2009 | 12:57 PM
Soon 2 B EVIL's Avatar
yeha call full race first before u wrap it up cause i know some people dont like there stuff wrapped up. If i remember correctly Full Race will void ur warrarty on the manifold if its wrapped.
Old Feb 2, 2009 | 12:58 PM
Yeah I'm not going to wrap it, I'm going to VHT paint it instead
Old Feb 2, 2009 | 07:52 PM
cij911's Avatar
I highly doubt Jeff or any at Full Race would void if wrapped (but call and find out)...Hi temp paint does nothing to reduce heat transfer (or keep engine cooler)...Coating is very different than paint...Good luck..
KevinD
Sep 8, 2014 07:50 PM
thewiz11144
Lancer Engine Tech
Dec 18, 2011 11:21 AM
helgusmc
Dec 7, 2010 05:05 PM
TitanMotorsport
Sep 3, 2009 09:29 AM
voidhawk
Northwest Region
60
Apr 4, 2008 12:42 PM
