Bosch 1000cc injectors on an Evo
Old Apr 28, 2009 | 06:10 PM
  #76
BBC's Avatar
BBC
where can one source another resistor pack? I checked mitsu parts but couln't find anything. Not a lot of junk yards around here either.
Old Apr 28, 2009 | 09:39 PM
  #77
GST Motorsports's Avatar
MR561990 Resistor,eng Cont
Old Apr 28, 2009 | 09:45 PM
  #78
mrfred's Avatar
Originally Posted by travman
I run them as well - they drive amazing, idle better than stock imo. I plan on eventually adding a second pump and jacking the fuel pressure as well, I am at 91-92% on e85 currently on them. They are really easy to tune and dial in as well, im 100% satisfied with them.
I figure these will be the last injectors I will ever own.........FINALLY.
Did you get the warm start issue ironed out?
Old Apr 29, 2009 | 08:23 AM
  #79
BBC's Avatar
BBC
Awesome, thank you!
Old Apr 29, 2009 | 08:32 AM
  #80
R/TErnie's Avatar
I have a good idea
Old Apr 29, 2009 | 09:16 AM
  #81
Done's Avatar
So how hard is it to bypass the resistor?
Also Im wondering if driveablity would improve over my precsion 780cc.
I currently have idling issues when A/C is on, and issues around 800rpm - 1500rpm, basically letting off the clutch I have to give alot of gas.
Old Apr 29, 2009 | 09:18 AM
  #82
less10's Avatar
Who tuned your car, what ems?
Old Apr 29, 2009 | 09:20 AM
  #83
Done's Avatar
Its tuned with ECUFLASH..
I tuned it..
Those are the issues I'm having and I cant fix.
I do have an open element filter, and im running a MAF TRANSLATOR.
But I feel the issues are still with the injector latencies.
Old Apr 29, 2009 | 11:39 AM
  #84
Done's Avatar
Does the harness for $7 each do the rewiring so itll work without bypassing the resistor?
Old Apr 29, 2009 | 11:43 AM
  #85
R/TErnie's Avatar
no it will not remove the resisitor pack...it simply allows you to connect your wiring harness to these injectors.
Old Apr 29, 2009 | 11:45 AM
  #86
evodood's Avatar
what harness? if you mean the ones offered with the injectors those are pigtails that convert your stock injector clip to fit the Bosch injectors.
Old May 5, 2009 | 04:21 PM
  #87
evodood's Avatar
bump
Old May 5, 2009 | 06:14 PM
  #88
dan l's Avatar
Originally Posted by evodood
So I'm assuming that the white is the supply and that the 4 blacks are the resisted power lead to each injector?
and that the resistor "pack" was just resisting to each of the blacks and had nothing to do with distribution to a specific injector???
and this is just any easy way of shorting them all together (so that i could use something different if i needed) so that there is no logner resistance to any of them when the signal requests an injector to be fired????
I'm done helping. post deleted. PM me if anybody wants info.
Old May 5, 2009 | 06:15 PM
  #89
dan l's Avatar
Old May 5, 2009 | 06:21 PM
  #90
dan l's Avatar
Last edited by dan l; May 6, 2009 at 03:00 PM. Reason: I'm done helping. post deleted
