4g63 to a 4g64 block
Old Feb 2, 2009 | 07:27 AM
josh prochaska's Avatar
i'm starting this to get some opinons on the 4g64 block i have reed alot about it .
How many people out there have done the swap. i killed my motor and ready to do some thing about it. i like the idea of the destroker kit to 2.1 but the bigest reson for wanting to switch is the price diff. if someone thinks i'm going in the wrong direction please let me know your opinons .
Old Feb 2, 2009 | 07:39 AM
dose anyone know if ams would put oil squirter's in a 4g64 block. also is there a stroker kit just for 4g64 to destroke it or do i have to get all the specks and order it.
Old Feb 2, 2009 | 07:44 AM
i do have an evo 8 crank but it did grenade a piston and rattled the rod around a few times do any of u think the crank my be usable or just screwed up. block took most the damaged. after piston meet balance shaft.
Old Feb 9, 2009 | 10:02 AM
SeanC's Avatar
Check out my post here:
https://www.evolutionm.net/forums/ev...work-pics.html
I'm using a 4G64 block with a MIVEC head. It's an easy swap, and 4G64 blocks are cheap.
You can use the factory 88mm crank or the factory 100mm 4G64 crank. All aftermarket cranks should work too.
SeanC's Avatar
I assume AMS can do this...my squirters were machined by LESCO on my 4G64 block.
Old Feb 14, 2009 | 11:56 PM
a2stepawd's Avatar
Have a machine shop look at the crank! You don't want to risk using a bad one!!
Where in IL you at?
Old Feb 15, 2009 | 09:02 AM
mazdadike's Avatar
theres a few good machine shops in chicago area also
Old Feb 17, 2009 | 08:42 AM
JdMeVo4's Avatar
http://www.kidzuku.com/StrokeOrNot.pdf
^^ There is alot of good info in here it may not answer the specific questions you have about using the 64 block but it should/will answer alot of questions on the 2.1destroked vs 2.3 strocker vs the 2.0.
Old Feb 23, 2009 | 08:06 AM
turbodream's Avatar
Good reading! Thank you
Old Mar 3, 2009 | 01:04 AM
antonio010's Avatar
That was awesome reading, I wish I had read that a long time ago!
Old Mar 10, 2009 | 07:29 PM
EvowagonIX's Avatar
good info
Old Mar 17, 2009 | 05:43 PM
VTEC Killer's Avatar
Personally I would go 2.2 all the way. 4G64 block, 94mm crank, custom rods and pistons. complete kit is available from Magnus Motorsports, K1(sold by wiseco) also has the 94mm crank and custom pistons made for it and I believe manley makes the rods. This motor is a true compromise of both the 2.4 and the 2.0\
I currently run the 2.4 in my galant and having a rev safe limit of 7500 (8000 if you want to push it a little) sometimes sucks and I wish I could take it to 9000 or 9500.
Old Mar 26, 2009 | 07:07 AM
FastAzzEvo's Avatar
any competent machine shop can tap for oil squirters.
boostawd16
Jun 7, 2016 10:28 AM
evo082006
Aug 5, 2009 12:16 PM
Johnboy1065
15
Jan 22, 2009 03:32 PM
SeanC
Nov 27, 2007 03:21 PM
sno_evo
Dec 12, 2003 12:50 PM
