need help asap
Old Feb 2, 2009 | 09:15 PM
jdmsego's Avatar
need help asap
i just installed upper and lower intercooler pipes and a front mount, when i take it down the road and hit boost it spits amd sputters and acts like it want to shut off only in boost checked all the clamps and reseted the ecu dont know what it could be can any one help
Old Feb 2, 2009 | 09:17 PM
LANCEREvo9MR's Avatar
Bov maybe........u still on the plastic bov
Old Feb 2, 2009 | 09:19 PM
HyaboostaIX's Avatar
I had the same problem after installing INT pipes. It's one of two things...either your car is hitting a fuel cut...but if you haven't changed the boost, probably not. Most likely...you need a tune. That was the case with mine. If you reset the ECU and drive around for a couple days without stepping on it, it may be ok...as mine was, but I would reccomend getting a tune as soon as you can. That would fix it for sure. In the meantime, it's fine to drive around.
Old Feb 2, 2009 | 09:20 PM
Smike's Avatar
Please do not double thread.
Did you do a boost leak test after the install?
Old Feb 2, 2009 | 09:22 PM
McLaren F1 2003's Avatar
sounds like a boost leak to me...
Old Feb 2, 2009 | 09:35 PM
jdmsego's Avatar
i have changed the bov, where would the boost leak be comin from checked all the connections on top only ones i couldnt check were the ones on the intercooler it self
Old Feb 2, 2009 | 09:39 PM
Smike's Avatar
Need to boost leak test. Search and read the how-to on it.
Old Feb 2, 2009 | 09:55 PM
frost318's Avatar
might be one of the hoses on the intercooler since you didnt check those.
