->Perfect weather, perfect shifting<-
Old Feb 3, 2009 | 09:49 PM
NYC4g63IX's Avatar
the 4g63 doesnt respond well when its cold, as do most engines. the same goes for the tranny. the oil is so thick and situated at the bottom. thats why the shifting feel sucks unless u warm up the car. i live up in nyc and its been 40 degrees or lower lately and i experience this all the time. i just get used to it haha
btw since my car is loud i get her going as soon as i start up. i just go real slow and never above 2k rpm
Old Feb 3, 2009 | 10:57 PM
nawaz's Avatar
Originally Posted by iy
I switched to BP Synchroshift II...shifts got much smoother. Still a little notchy when cold but much much better than before.
I'll keep that fluid in mind the next time I change the tranny fluid. Thanks.
Originally Posted by DocCola
see i have no problem with my 2nd gear, its usually 3rd, sometimes 4th. I'm about to roll 24k miles which means I'll have my 30k stuff to do soon. I need to find a better transmission fluid
I'm at about the same mileage mark as you since I just past 25k miles. Sometimes it can be 4th gear for me as well.
Originally Posted by fryedchikin
When the the weather is cooler, I have learned that letting the clutch out a little bit slower really helps with smoother shifting.
hmmm...interesting (I also have to be very gentle with my clutch engagement and shifting....Or else I can get pretty rough shifts).
Originally Posted by al3xx
I just got an Exedy Twin HD installed, and sometimes it's not letting me shift into first. I contacted the shop that installed it, but could it be something related to the temperature outside? My gut reaction is that it isn't...because it was like 32 outside this morning and I had a little trouble, but in the afternoon it was in the 70's and I still had a few instances where it wouldn't get into gear.
A little off topic, but thoughts?
Actually, I face similar things. I also can't go to 1st gear at times when I'm at a stop. Also, when I start the car and I try to go to reverse, sometimes it won't let me into reverse....And I keep trying 5-6 times, and then it finally goes in.
Originally Posted by porsherules911
changing fluids helped a little for me but no matter what fluid i use 2nd gear is just impossible to get into without a clunk or grind.
Same here man.
Originally Posted by benniboi08
[If you think texas weather is bad, come to the east coast by the tri-state. Shifting in temperatures below freezing is painfullllll...lol but we learn to deal with it. Most of us try to warm our cars up at least 1-3 minutes but some times you just gotta get going. As for all trannys from other vehicles, i'd have to say yes. Happened in my prelude 5speed and happened to my brothers miata. Its not in operable or should i say optimum temperature. I just warm my car up for 1 minute and take it easy for the first couple of miles, then im good to go.
And I'm very thankful not to be in a colder state...Whewwww!! So it happened with your Prelude also.....hmmmm....I guess my problem is just a "car thing" that happens.
I guess I just have to get used to it also when it's cold here in Texas. Oh yeah......doesn't your car feel louder when you start it in the colder times and especially if you first start driving and when you don't get a chance to warm-up?
Old Feb 3, 2009 | 11:20 PM
TS8's Avatar
TS8
The Evo five speed is known for the shift problems compared to the rear wheel drive trans like the ones in the Subys.
Our trans uses wires/linkage, and can get knotchy for all the previous listed issues.
From 05, they started to use Teflon coated shift wires for smoother feel.
I have the 03, and it has similar issues especially when cold from dead stop.
I installed the Under hood shifter linkage bushing (aluminum), and it helped somewhat, especially with the positive feel. My next install is the shifter base surround bushing (poluurethane).
Old Feb 3, 2009 | 11:23 PM
nawaz's Avatar
My tuner installed a good motor mount in my Evo IX MR, and it helped somewhat actually.
Old Feb 4, 2009 | 12:10 AM
al3xx's Avatar
Interesting...what clutch do you use? I'm probably going to bring my car to the shop and see what they say, I'll get back to you with any news. I'm still breaking in the clutch...let's hope it goes away with a few more miles.
Old Feb 4, 2009 | 12:29 AM
nawaz's Avatar
I had my ACT Street Disc Clutch & Streetlite flywheel installed when I had about 18,000 miles on my Evo (currently have 25,000 miles), but the problem even happened before I got my clutch replaced.
Old Feb 4, 2009 | 12:08 PM
evodownunder101's Avatar
Yea i get the same when its cold out hear.
Old Feb 4, 2009 | 01:47 PM
nawaz's Avatar
So I take it that what I experience is normal and we all just have to let the transmission fluid really warm up until we feel a positive difference. I now believe that it's just a manual transmission thing and I just have to work around it I guess.
Old Feb 4, 2009 | 03:36 PM
boostincincy's Avatar
Im sick of it, I'm getting an STI....
well, maybe not yet.
Old Feb 4, 2009 | 03:51 PM
06MRV8Killer's Avatar
Yes, I have noticed this and yes its annoying, and no, not all vehicles do this....
Old Feb 4, 2009 | 09:12 PM
nawaz's Avatar
uhhh.....ok......I guess Evo's are some of the only vehicles that have this shifting problem...?.....Correct me if I'm wrong. Thanks.
Old Mar 17, 2009 | 06:01 PM
srcevo8's Avatar
FWIW here in sunny So Cal I experience the same shifting issue until the car has warmed up. I can't imagine you guys in snow dealing with this.
My 350Z did it too but it was nowhere near as bad as the Evo is. Even in 80-degree weather it's a problem until my temp gauge gets up halfway. Then things feel better.
Old Mar 17, 2009 | 06:15 PM
jjm4life's Avatar
when its cold out its especially hard to engage reverse. typically i have to get 1st then go to reverse. just the nature of fluids and cold weather.
Old Mar 17, 2009 | 07:24 PM
b00stin evo8's Avatar
my 1st and 2nd have the same problem in the cold chicago winters, but once it gets up to temp its pretty smooth. I will however wait till summer when the temp is high and see how it does, im sure it will be marginally better. Dont worry though cars are picky things!
Old Mar 17, 2009 | 07:32 PM
Silver05Bullet's Avatar
dont use that fluid if you have any power or unless you change it at every oil change or the tranny will say goodbye
