Installing Cams do I need new Timing Belt and Tensioner
So I've got about 45K miles on the evo 8, going to get M2 cams and FP springs installed here soon. Should I replace my timing belt, tensioner and balance shaft belt while I'm at it. or should I save that when I need to do the water pump. BTW when does Mitsubishi recommend I do my water pump?
You love to post ***** man...
-E
You are getting there. If you plan on keeping the Evo and don't think you'll be accessing the timing cover area again in the near future I would recommend just taking care of the Timing Belt now while you are in there.
So what do I need to do the timing belt?
- Timing Belt
- Balance Shaft Belt
- Timing Belt Tensioner
- Water Pump & Gaskets
Anything else? Should I replace my Serpentine belt at the same time?
- Timing Belt
http://www.mitsubishiparts.net/catal...ction=586#1523
Thought about getting this Timing belt kit, anyone know how much power the stock oem belt is good to? I don't plan on going past 500 whp once I get my FP Red.
Thanks
Thanks
Id definatly do the belt now makes no sense to take it back apart in 10K miles. I would if it were me replace the tensioner now . $80 bucks now for a or a couple of hundred if it fails for new valves. After you get it back together rotate the engine 2 times clockwise and recheck your timing marks before starting. It will give the tensioner a chance to take up the slack in the belt also.
I got a timing belt, balancer belt and all pulleys changed recently, but tensioner B - part MD115976 was wrong according to my mechanic for Lancer Evolution 5 GSR. The part that they had sent me is much thicker and slightly diff shape. He also told me that the tensioner B used by my engine is the same as on EVO 8.
C:\Documents and Settings\Misik\Desktop\tensioner b\PICT0004.jpg
