Turbo inputs
Old Feb 4, 2009 | 09:13 AM
lilgunz's Avatar
Turbo inputs
I got an 03 EVO VIII and one of the last things on my list to get is my turbo, I am thinking an FP Green or an FP Red. my goal is anywhere between 400 -450 whp and still have the car be reliable cause for now it is the DD.
this is what is on the car:
-megan exhaust manifold and turbo outlet
-tanabe concept g turbo back exhaust and downpipe
-Random technology high flow cat
-AEM short Ram intake
sitting in the garage waiting to go on:
- BC 272 cams
-Greddy Electronic Boost controller
-walboro fuel pump
-680 cc injectors
-turbo XS intercooler and hard piping
-unorthodox racing underdrive pulleys
and still on the list to get is:
- turbo ( red or green)
-clutch
-ECU reflash
let me know any ideas or opinions
Old Feb 4, 2009 | 09:15 AM
evane's Avatar
exedy twin hd for the clutch and fp red for the turbo for sure
Old Feb 4, 2009 | 09:19 AM
jjm4life's Avatar
dont count out the cbrd bbk. more power than a green, less than a red though. my act clutch is holding the bbk power very well if you dont feel like spending the money on the exedy twin.
Old Feb 4, 2009 | 09:20 AM
SilverBulletIX's Avatar
Im actually in the same boat right now. Right now I make 380 on Pump and 420 on race with the green so if your goal is 450 you will probably have to go with the red. From what I understand it is in your best interest to consider building the motor if you plan on pushing the limits of the red and run it reliably especialy since this is your dd. If you plan on just running pump with the red you can probably get away with not building the motor. You will need bigger injectors with this turbo though...
Old Feb 4, 2009 | 09:42 AM
lilgunz's Avatar
alright cool thanks for the inputs, I was planning on getting bigger injectors, that is just what I have right now. and was planning on getting the an ACT. anybody else have opinions still would be glad to hear them
Old Feb 4, 2009 | 11:40 AM
Evolessfornow's Avatar
You might want to get injectors that flow more than 680cc for 450whp. At least 750-880's.
Old Feb 4, 2009 | 12:15 PM
lilgunz's Avatar
was gonna sell my 680cc ones cause they have never been in the car, and still sit at home in the package. once I sell them get bigger ones, probably 720cc
Old Feb 8, 2009 | 11:35 AM
lilgunz's Avatar
What do you think that my car would make hp wise with just the stock turbo? and how high do you think that i can boost the stock turbo's psi?
Old Feb 8, 2009 | 10:16 PM
noypiC50's Avatar
don't count out the stock turbo yet, my 03turbo made 265whp on a low reading mustang dyno with just tbe with hfc, walbro, using ecuflash running between 19-21 psi. stock 03's make 210-220 on this dyno.
Old Feb 9, 2009 | 01:00 AM
sparky's Avatar
720's are not enough injector for the Red.
Old Feb 9, 2009 | 08:44 AM
grillpt's Avatar
680's are enough for the BBK. Go this route if your thinking Green, more power and better spool from what I've seen.
Old Feb 9, 2009 | 11:09 AM
lilgunz's Avatar
yeah I have been looking at the bbk more now and I think I like it alot more than the green, from what I have been reading.
Old Feb 9, 2009 | 11:13 AM
midlifecrisis's Avatar
Look at the Tomei turbo also.
Old Feb 9, 2009 | 07:22 PM
dastallion951's Avatar
good luck on what u decide, u should learn on this forum nobody is gonna really agree, cuz everyone thinks different i have an 03.... im gonna sacrifice a few hundred rpms spool for a lot more top end power...which if u think will also help u get a bit more gas mileage, seein as how with my supporting mods, i hit full boost on my evo around 3300-3400 around 24 psi spike....so good luck n post a dynograph
Old Feb 9, 2009 | 08:19 PM
sparky's Avatar
On pumpgas, Chad Block seems to favor the 780 injector size for a bolt-on Evo with his BBK.
