OEM Timing Belt Limits?
Old Feb 4, 2009 | 11:40 AM
sdfontanini's Avatar
What are the limitations on the OEM Timing Belt?
I'm installing Cosworth M2 cams along with a Full Race Header on my stock 8 turbo. Car's tuned to 30 psi on E85 and will/should be around 400 whp. Will the OEM belt be sufficient or should I go with one of the aftermarket belts like Gates, Greddy, HKS, etc? I'll eventually be putting on a FP Red and should be well into the mid 400's by then. Any help would be appreciated.
Thanks,
- Steve
Old Feb 4, 2009 | 12:00 PM
EvoDom's Avatar
greddy ftw again lol
Old Feb 4, 2009 | 01:03 PM
4g63tFan@tic's Avatar
If your going to break it down to install cams, you might as well go ahead and install a high-strength t-belt. Greddy is good, but i prefer Power Enterprise myself. The extra security just gives you that warm fuzzy feeling. Do it, Do it
Old Feb 4, 2009 | 04:35 PM
apagan01's Avatar
many many people running the OEM with over 800WHP,,, AL dyno flash usto or still runs the stock
Old Feb 4, 2009 | 04:40 PM
Bimmubishi's Avatar
power has no relation to the timing belt. The stock one is as good as any other. Gates makes them all anyway, save for the stocker.
Old Feb 4, 2009 | 04:47 PM
mazdadike's Avatar
how much deos a new stocker cost in comparison with a aftermarket one
Old Feb 4, 2009 | 04:49 PM
Bimmubishi's Avatar
Probably close. The gates belts are a great value.
Old Feb 4, 2009 | 05:10 PM
gsrboi80's Avatar
I have the Gates on my car since the first change. Second due in 10k
Old Feb 4, 2009 | 05:59 PM
TIBOevo's Avatar
i ran the stock belt till it broke well, the teeth finally gave. it lasted 120k. and i dog the **** outa it.
Old Feb 5, 2009 | 04:46 PM
David24's Avatar
How many miles do you have on it? Even though you're doing cams I don't think the belt has to come off if you decide to stick with the stock one. Isn't that what the t-belt tensioner is for?
Old Feb 5, 2009 | 04:51 PM
Gary@MellonRacing's Avatar
i have the oem belt making 418hp and will change the belt before the manufacture requires it becaude its oem
Old Feb 5, 2009 | 04:52 PM
my opinion
if u have use it no problems
if ur going to buy it buy the gates racing one and u wont have to change it so soon as the oem one ...
Old Feb 5, 2009 | 05:05 PM
jamevo8's Avatar
I had mine changed at 57000 miles and the old one still looks new.
Old Feb 5, 2009 | 05:08 PM
Dan@DrivenInnovations's Avatar
greddy belt and power enterprise are all made buy the same company called gates.
jmelocik's Avatar
Actually even the manufacturers of the aftermarket belts recommend changing them at the factory interval. They may advertise higher strength and longer life but you should not risk your high performance or even your stock engine for a fairly cheap part like a timing belt. I make over 340hp and run a stock belt, I've got friends running in excess of 500whp running the stock timing belt. I've never seen a stock timing belt on the 4G63 break from excessive power only from lack of maintenance or abuse or other mechanical failure.
Josh
