Aftermarket FMIC weight > Stock?
I'm not sure I'd call 12 pounds "only a few lb difference," especially as it's more than twice as heavy as the OEM component, AND it hangs just about as far forward on the car as possible.
But yes, a bar/plate IC by the nature of its construction is significantly heavier than a tube/fin design.
I deliberated whether I wanted to go with an aftermarket IC for a while, because I knew of the weight disadvantage, but eventually decided it was worth it, because I'm running peak boost of over 30 psi, and I do track days with my Evo, where I'm beating on it for much longer than 12 seconds at a time.
Here are some detail pics of the XS-Power IC...
Here's the XS-Power IC installed, before I replaced the bumper cover:
OEM vs. XS-Power IC:
And here are some views of the difference between bar/plate and tube/fin ICs inside...
OEM IC:
XS-Power IC:
Note that the fins inside the XS-Power IC are of the split-louvered design, which according to Nisei's IC design tutorial, is the most effective design for cooling the charge air - better than "bump" or "square" fins:
http://www.niseiengineering.com/imag...erTutorial.swf
mrm95
Jan 2, 2014 03:18 PM
