Swap spark plugs and car wont start anymore?
OK I wanted to change my spark plugs today since I haven't since last year I drive my car once a week so don't use it that much,
I started yesterday to get it in the garage and this morning I changed the spark plugs to copper and the car started just fine but didn't last more then a minute and it shut itself off so now i have no more spark.?
the engine turns and everything looks fine but have no spark just don't know where to start looking thank's?
I removed the spark plugs and istalled the old ones no spark tried tried to disconnect the HKS DLI and plug the stock coils back to stock and no spark it has fuel I can smell it on the plugs so it is ignition problem we all are thinking that is the cam sensor so I will try that next
if you didnt use torqe wrench to tighten the spark plugs, i think you tighten too much. i thing head is broken, i think something else might be broken. i think you should go to machanic shop. i hope you its not a big problems. good luck.
well I used to have the NGK iridium ones but I installed the NGK BPR8ES and they are gapped to 0.24 all of them and I used a torque wrench to install them most of the times I will try to check for some fuses again tomorrow as well the computer but the computer seems to be working since I flashed the other day installed another map
guapoholic
24
Feb 24, 2017 07:47 PM
bboy_RES
Nov 7, 2007 10:16 AM
