Chunk of metal on transmission drain plug???
Old Feb 8, 2009 | 09:04 PM
Johnboy1065's Avatar
Originally Posted by Slovo
If you can do an engine, Trannies are way in your league! So, you havnt heard any whining in any of the gears?
I have heard no whining in any gear at all. I'm guessing the damage done is minimal right now. so it's good I caught it early. HOPEFULLY that will mean it will be cheaper to fix.
if my final drive is messed up I'll probably go ahead and upgrade it to the 4.11 ratio since I have been thinking about doing that anyway.
Old Feb 9, 2009 | 09:23 AM
justa4banger's Avatar
damn...thats a big piece
Old Feb 9, 2009 | 09:25 AM
kimletrim's Avatar
Registered User
Quartermaster clutch...that kinda explains it. That multi-plate clutch is like an on-off switch to the transmission. But it sure does hold the power.
Old Feb 9, 2009 | 09:27 AM
gsrboi80's Avatar
Wonder how much longer she would have lasted. She's out though so get her built.
Old Feb 9, 2009 | 09:33 AM
hotrod2448's Avatar
Absolutely a tooth.
Old Feb 9, 2009 | 11:06 AM
BadBoy818_818's Avatar
how much would it cost you to fix it around?
Old Feb 9, 2009 | 01:33 PM
I have no idea how much longer it would've lasted, even though this is kinda bad luck, on the bright side I think I caught it pretty early on so hopefully damage is minimal.
Old Feb 9, 2009 | 01:34 PM
Fast_Freddie's Avatar
Veteran: Navy
FYI Mfactory makes two configurations of the EVO final drive... might wanna check them out. If you decide this may be an option let me know I may be able to hook up a decent price, my buddy runs the Team Mfactory work shop.
Old Feb 9, 2009 | 01:37 PM
I've been thinking about doing a 4.11 final drive ratio since my car is a 2.3 liter, but am unaware of all the positive and negative affects of a 4.11. I started a thread about it here: https://www.evolutionm.net/forums/ev...ive-ratio.html
raytrix
May 7, 2010 07:40 AM
Yousef
Jun 21, 2009 07:39 PM
spdrcr456
May 21, 2008 05:17 PM
MRedition
Aug 23, 2006 08:20 PM
Zippo41189
Jul 19, 2006 12:03 AM
