Spun Rod Bearing
Old Feb 11, 2009 | 11:29 AM
mindoftw's Avatar
Originally Posted by justa4banger
if you had a spun bearing you would know rite away...
Really would it be knocking like crazy? If i rev it and when the RPMs start to decel i hear a little rattle but its not like the videos i have seen and i didnt know if it was possible that the crank could be worn down maybe?
Gary@MellonRacing's Avatar
what oil shoul dhe use then
Old Feb 11, 2009 | 11:45 AM
Mr. Evo IX's Avatar
Well if your getting low oil pressure (light flickering) and you hear some rod bearing knock on decel that's not good news. Obviously the vid I linked to is an extreme case (it's knocking at every rpm not just on decel) but that's the type of sound your listening for. Also if you notice in the video they localize the sound to the bottom of the block. If it's a rod bearing it will get worse (knock will get louder), engine will lose power.
As far as engine oil goes, most people run Mobil 1 10w30 as specified by the mfr.
Old Feb 11, 2009 | 11:54 AM
justa4banger's Avatar
if something is wrong with ur engine its pretty much commen sense...i use mobil 1 10w 30....if your oil light only comes on at idle and if you rev it and it goes away than its more likely your oil sending unit sensor...
Old Apr 20, 2009 | 12:13 PM
mindoftw's Avatar
Hey i am reviving my old thread from the past cause i had a quick question.
What kind of oil pressure should i be seeing at cold start idle, warm cruising, and warm idle?
Old Apr 20, 2009 | 03:07 PM
leecavturbo's Avatar
take it to a specialist ?
Old Apr 20, 2009 | 03:21 PM
evil_eagle's Avatar
You would know if you spun a bearing, after a bearing spins it will seize to the crank within 5-10 miles and the car would just quit. Not to mention the horrid sound it puts out, you can hear it a mile away, it sounds like a paintball gun on automatic settings X10 "PAP PAP PAP PAP" As the RPM rises.
Now a damaged bearing will tap, there is a difference between a spun bearing and a severely damaged bearing. Spun bearing is self explanatory, it will spin around in the big end of the rod with the crank journal. An un spun bearing that is seriously damaged will make a pretty good tapping noise.
Mauricio Evo IV
Oct 18, 2016 06:55 AM
Dannievo
16
Apr 26, 2015 08:54 PM
smoOVE
18
Jul 23, 2012 11:01 AM
04WickedWhite
Jun 1, 2011 10:57 PM
liljj2221
Oct 23, 2006 08:51 AM
