Evo 9 MR BOV vs Tomei BOV
Old Feb 11, 2009 | 06:43 AM
Nomad4g63's Avatar
Whats the difference? How much boost do these BOVs hold and how much do they hold crushed?
If you've owned either 1 tell us about your experience PSI? boost leak test? hold long u been running it etc...?
Old Feb 11, 2009 | 06:58 AM
beatrush's Avatar
Running the Tomei BOV... no problems at all...curently running 25PSI... also holds boost up to 30PSI without any issues...
Don't think that there are any differents between those two BOV's?!
Old Feb 11, 2009 | 07:02 AM
N3VO's Avatar
i just switched from the plastic 8 to the ix bov which is the same as the mr. it is very nice there is a big difference. i would recommend getting the ix bov.
Old Feb 11, 2009 | 08:59 AM
noypiC50's Avatar
the tomei has stiffer spring and will hold more boost than a evo9 metal bov. No drivability issues also for the tomei, really a nice piece.
Old Feb 11, 2009 | 09:01 AM
mister_pants's Avatar
Tomei installed a few years ago, been a great recirc valve, no issues, never had any issues holding boost and it's stealth too.
Old Feb 11, 2009 | 09:28 AM
Nomad4g63's Avatar
how much boost is everybody running!?!?!?!?
Old Feb 11, 2009 | 09:46 PM
Nomad4g63's Avatar
bump!
Old Feb 12, 2009 | 03:39 AM
sparky's Avatar
It depends.
Old Feb 12, 2009 | 05:41 AM
Nomad4g63's Avatar
Originally Posted by sparky
It depends.
Alrighty ill ask the right question.
Can a stock BOV crushed hold 26-27psi?
Old Feb 12, 2009 | 07:51 AM
Steve93Talon's Avatar
Crushing a BOV is the last thing you wanna do. It's something that DSMers did 10 years ago when we didn't know any better. To correctly mod an IX BOV to seal over 25psi, you can do the "Gus/Dodge Garage/Dejon" mod. That is, plug the fast release port on the bottom and drill a hole on the side to vent it instead. This will keep the pressure on top of the diaphragm always greater than on the valve face. In my experience, it barely affects the valve's ability to release quickly on throttle lift.
We ran 35psi on a stock 1G DSM BOV with this mod. I've even done it to a plastic VIII valve and it works just as well, although the plastic valve seats tend to leak a little at any pressure.
Old Feb 12, 2009 | 01:51 PM
MR2Racer28's Avatar
i prefer the stock EVO IX blow off valve. Just my opinion
Old Feb 12, 2009 | 11:33 PM
iloveboost's Avatar
i need some clarification on this subject. i am buying a ix bov, but are all ix bov's metal? i ran into someone selling a plastic one and it threw me off.
Old Feb 12, 2009 | 11:40 PM
Kdash106's Avatar
ix bov is good till 26ish, if you crush it u can hold little more, why don't u just get a APS bov, or synapse Synchronic bov?. If the synapse BOV was smaller, I'd get that since it holds boost like a champ and it don't flutter at all, but aps is also a good choice.
Old Feb 13, 2009 | 03:26 AM
sparky's Avatar
....Can a stock BOV crushed hold 26-27psi?
Supposedly the IX DV w/o crushing will hold about 25#. The only problem is that uncrushed they start opening at about 11#, which really hinders spoolup and hurts midrange torque production. Crushed, mine easily holds 26-27#.
Old Feb 13, 2009 | 08:21 AM
I tested a stock VIII and IX BOV, the plastic VIII held to about 14psi before starting to open, and the IX metal valve held about 24psi before the cracking point. Once I performed the leak-stop mod, they both held as much as my regulator would put out (75psi I believe). The only difference at that point was the fact that the plastic one always seeps a little air past the valve seat because it doesn't seal as well as the metal valve even when it's fully closed.
