Evo 9 MR BOV vs Tomei BOV
Old Mar 31, 2013 | 01:22 PM
  #31
lescook's Avatar
will the tomei hold over 30psi with out any prob
Old Jun 9, 2013 | 06:39 AM
  #32
lescook's Avatar
i just switch from the 8 to the 9 and love it im running 22psi and i have a buddy running 30psi and no problems
Old Jun 9, 2013 | 08:25 AM
  #33
WRC-LVR's Avatar
Originally Posted by Steve93Talon
I tested a stock VIII and IX BOV, the plastic VIII held to about 14psi before starting to open, and the IX metal valve held about 24psi before the cracking point. Once I performed the leak-stop mod, they both held as much as my regulator would put out (75psi I believe). The only difference at that point was the fact that the plastic one always seeps a little air past the valve seat because it doesn't seal as well as the metal valve even when it's fully closed.
So here is the answer.....the IX holds 24 w/o cracking on the bench
I know I have had mine on since 2007 and it does fine at 25 tapering to 23 at 8000 rpm. On the Stock 05 10.5 MR turbo . All clamps are Tbolt. Plus there is no driveability issue period . If I needed more or thought it was limiting spool up then i would perform the crush.
Vivid Racing
12
Jul 30, 2014 03:40 PM
cosmicblueGSR
10
Nov 15, 2013 06:20 AM
victim619
13
Mar 19, 2012 06:45 PM
Clipse3GT
40
Jan 13, 2011 07:31 PM
Mellon Racing
193
May 13, 2010 07:08 PM
