fuel pump setup
Old Feb 12, 2009 | 08:56 PM
X91EVO's Avatar
Registered User
fuel pump setup
Is a double Walbro 255lph fuel pump kit really necessary???
plan on running around 25-28psi. I want to go with the best from the start and a single Walbro 255lph should do the job right??.. or is the double Walbro 255lph the way to go?
Old Feb 12, 2009 | 11:48 PM
chaotichoax's Avatar
well you kinda left out everything that is important
turbo?
type of fuel?
additives (meth/alky)?
if we are talking pump gas and a stock turbo...a single walbro will be fine...a little searching could have told you that
Old Feb 24, 2009 | 04:23 PM
X91EVO's Avatar
Registered User
plan on running meth... on 93 pump.. maybe a map for some c16 idk yet... stock turbo as of now plan on 30r or 35r in the far future
..I just dont see that many double pump systems so I was wondering if its worth it
Old Feb 24, 2009 | 04:24 PM
BocaShula's Avatar
No you're fine without a double pumper.
Old Feb 24, 2009 | 04:47 PM
jmelocik's Avatar
Some say that the single Walbro is good to around 500 whp. I may be below that but I'm going to a double pump setup for nothing more than the assurance that I won't run out of fuel later on. Kinda like doing a Walbro on a stock turbo, stock boost car. Doesn't really need it but it's cheap insurance.
Josh
Old Feb 24, 2009 | 05:46 PM
X91EVO's Avatar
Registered User
thanks for the input... yea josh I had the same thoughts as you until I saw the dam double pumper is around $500 haha
thats why I really wanted to know what others thought
Old Feb 24, 2009 | 06:02 PM
inco9nito99's Avatar
Single Walbro with FIC1050 is plenty for a car on Meth. Beyond 500awhp, look into the double-pumper from Buschur.
Old Feb 24, 2009 | 08:26 PM
X91EVO's Avatar
Registered User
1 dollar per horsepower I guess
Im working with minimum wage here...why can evo parts be cheaper!!!
Old Feb 24, 2009 | 08:29 PM
heel2toe's Avatar
I too think you will be fine with a single walbro and some large injectors. Plus when mixed with meth your injector duty cycle is lowered so your chances of maxing out the pump and injectors is reduced.
Old Feb 24, 2009 | 09:08 PM
X91EVO's Avatar
Registered User
hey I completely over looked that!! thanks and seeing 600hp isnt anywhere within my range anytime soon single walbro sounds good to me
thanks everyone
MacMan
50
Jan 8, 2015 01:04 PM
SUBIIKILR
Feb 6, 2013 05:40 PM
jfeo
Mar 5, 2012 01:37 PM
fenster
Jun 10, 2011 08:06 AM
Megadeth2118
Lancer Aftermarket Forced Induction Tech
Nov 1, 2004 02:36 AM
