Taking a while to turn over..
Old Feb 18, 2009 | 07:24 PM
DJJimGreen's Avatar
Number of things I guess it could be, but I guess asking if this "is normal" is in order.
I've got a 35r turbo set up with 1000cc injectors. NGK BR8ES spark plugs and so on.. coil packs are in good order too..
Any ideas on why it could take up to 5 cranks for the car to start up? =(
Old Feb 18, 2009 | 07:34 PM
Arkitek's Avatar
bas starter,bad alternator, bad battery?
Old Feb 18, 2009 | 09:57 PM
DJJimGreen's Avatar
well if it was the alternator, wouldn't the battery eventually die? if it was the battery, wouldn't the car not start at all? if it was the starter.. well I dunno what the starter would do...
Old Feb 18, 2009 | 10:04 PM
drewdq's Avatar
what are your fuel trims? your injector latencies/scaling could be off.
Old Feb 18, 2009 | 10:20 PM
DJJimGreen's Avatar
sounds about right.. because I have no idea what you're talkin about.
Old Feb 18, 2009 | 10:32 PM
Torque07's Avatar
is your battery in the engine bay? or did you relocate it
Old Feb 18, 2009 | 10:53 PM
IEXCELR8's Avatar
Stock ecu?
Old Feb 18, 2009 | 10:55 PM
sikrsix's Avatar
+1 If the battery is still in your engine bay, then see below.
Sounds like you just installed injectors and haven't been tuned.
Old Feb 18, 2009 | 11:00 PM
DJJimGreen's Avatar
Why yes, thank you for the help.... ***.
Originally Posted by IEXCELR8
Stock ecu?
Negatory.. AEM
When I bought the car from the dood he says he had it pretty well tuned from some shop.. so.. I guess I should just mess with the latencies/scaling and it should quicken the start up?
Old Feb 18, 2009 | 11:01 PM
sikrsix's Avatar
The battery relocation question was a serious one from torque07 and from me. We are trying to help you, keep an attitude and see how far you get in fixing your car.
Old Feb 18, 2009 | 11:04 PM
DJJimGreen's Avatar
didn't sound serious. My apologies if it was.. I have a hard time sensing sarcasm through the comp. And seeing he only had 51 posts, I didn't trust him as much as you by far.
Old Feb 18, 2009 | 11:09 PM
sikrsix's Avatar
Only reason is my friend has a 240sx with his battery in the trunk. It takes a couple extra turns and sounds like his battery is weak while starting. If the battery isnt in the trunk, then forget this for trouble shooting. I see you have the AEM which I have zero experience with.
Old Feb 18, 2009 | 11:15 PM
DJJimGreen's Avatar
Cool.. then thanks for the attempt. I'm going to go with AEM being the culprit.. dang..
Old Feb 18, 2009 | 11:19 PM
sikrsix's Avatar
My other friend who turbo'd his 240 has 1000cc on a chipped ecu. Takes like 8-12 turns to start. Id say injectors aren't dailed in correctly. How long you have this car for? New problem, or slow start from day one?
Old Feb 18, 2009 | 11:30 PM
vletnguyen's Avatar
all AEM EMS equipped evo's will have this issue. no way around it, other than some "trigger disc" but that's way too much work unless youre already building your motor.
