P0335 & P0340 How do i fix this??
Old May 24, 2009 | 02:33 PM
FX11's Avatar
yeah def check the Cam angle sensor, because mine was broken
Old Jun 1, 2009 | 10:54 AM
Chabada15's Avatar
new update...codes are back...seems like if i turn them off and drive for 20 minutes or more they turn on once i go WOT
Old Jun 1, 2009 | 11:53 AM
Gary 805's Avatar
yeah wierd thing. i just got them again today. all of a suden i stalled the car out and the car looked as though it got no power at all. Yet i could hear the car trying to start over.
Got the car to start then i took off and went and cleared the code.
Old Jun 4, 2009 | 08:57 AM
TwoFour's Avatar
I just had this same p0335 code, just last night my car would slowly turn over and this morning would not start, so I sat there for 10 minutes then it barely started, I drove home and it threw the CEL. It comes up as the 0335 code. Probably my battery?!?!
Old Jun 4, 2009 | 09:06 AM
Chabada15's Avatar
if your car is having a hard time starting then replace your battery
Old Jun 4, 2009 | 09:53 AM
TwoFour's Avatar
I will be doing that today
Old Jul 15, 2009 | 10:09 PM
xceler8rob's Avatar
I just got these codes on my car after my cam,valvespring, cam gear, headstud install. I think mine is on either because my sensors aren't plugged in real well or because my cam angle sensors are bolted in upside down or something.
Bump to bring this back for someone else to answer or give ideas.
Old Jul 16, 2009 | 12:13 PM
Chabada15's Avatar
you really cant have either of those, if you dont think its plugged in well then you should throw sum dielectric grease on it, and it cant be in upside down...
Old Jul 16, 2009 | 09:04 PM
xceler8rob's Avatar
I'm not talking the plug, I'm talking the acutally piece that bolts into the end of the cam. It has grooves on it that the sensor reads when they pass by it. I'm kinda thinking I have one in upside down so it's throwing the sensor off. I tired unplugging it and what not, car will fire and die right away. Maybe the ecu is thinking it's out of time by 180 degree cause the sensor is upside down and therefore killing the motor as soon as it starts up? Maybe a safety mechanism??
I just need to pull both caps off I guess and look and see where there are.
Old Jul 16, 2009 | 09:14 PM
Piro Fyre's Avatar
Originally Posted by whitedsm97
i have the same problem to with the two same codes as well. but my car won't spark on cylinder 1 and 4. now it won't even start and if it does, it'll run on 2 cylinders only. someone help.
Check your ignition coil. Had this problem before and it turned out that my ignition coil blew up from too much resistance and I was only running 2 cyl.
Old Jul 20, 2009 | 09:30 PM
xceler8rob's Avatar
Mines fixed! Was pretty easy and the first thing I thouht to check after obvious (plug). My cam angle sensor trigger was loose from the cam. Took cover off and torqued down to 17ft/lbs. car runs fine minus that it needs a reflash real bad after the cam install!
Old Feb 3, 2011 | 04:54 PM
blacktab420's Avatar
Okay guys, here is my problem. I read my SES codes and got P0300 (which i don't care because it always pop up randomly ) and P0335, P0340.
My car is stock except an unknow testpipe and i have 53000k on the car.
The difference with you guys is that my car runs fine ... The only time the car had a f*****k PITA to start was two weeks ago, when the temperature was -22 F. Took me like 5-6 try to start the car and it finally starts but was running like a pig which is totally normal since this car do not have block heater and i don't have pan heater neither.
So is it dangerous if I keep driving my car ? i have cleared the codes and personnaly, i think i should not worry unless codes comes back ... ?
Thanks !
Old Nov 6, 2011 | 10:43 AM
a twinky's Avatar
ok here is my issue. i am getting just a p0335 code and my car will nbot start for nay reason......it try sometimes u get a start then an instant death. im not finding any loose conections..... and the code cleared and now i get a "0" on my obd.....still no starting any guesses or a tip where to look
p.s. my car has 28k on it ran fine with no warnings i threw the code on an on ramp i drive home no issue of any kind and never started back up...
Old Nov 9, 2011 | 06:49 AM
MrSquirr3l's Avatar
lol seems my car is now doing this as well. i am suspecting that it might be from my plugs with the coil packs on them. just curious if any of the other guys that had these codes got it fully fixed and if so what was the issue?
Old Apr 20, 2012 | 07:26 AM
1fastblackevo8's Avatar
bump to keep this thread alive. Im having the same issue. But my car shuts off while on the highway.
