Help: all three ACD lights are on
Old Mar 1, 2009 | 06:35 PM
urbanemyth's Avatar
Alright so here is whats up. this weekend i was installing a new Sub into the car. and well when i finished everything... i turned on the car and the ABS (anti lock) light was on...as well as all three of the ACD lights... (snow, gravel, tarmac)...well idk what i did cause the car drives fine...and there isnt any problems...i changed the ABS fuse but that was okay...so im gussing i might have popped a different fuse somewhere else cause thats all that can happen right?
Secondly.... While tyring to turn on the heater today my AC is out as well... If yall can give me any suggestions as to where to look or what to do.... im up for any suggestions....
THanks
Steve
Old Mar 1, 2009 | 07:01 PM
SICK9's Avatar
You checked the fuses under the dash and the fuses/relays under the hood?
Sounds to me like you wired it wrong and shorted a relay out.
please elaborate more?
Old Mar 1, 2009 | 07:16 PM
urbanemyth's Avatar
where can i check the relays?
do u know what fuses are which under the dash?
Old Mar 1, 2009 | 07:18 PM
NativeSS's Avatar
it's all in your owners manual.
to check your relays you will need a relay tester, you cant just look at 'em and tell they are bad.
Old Mar 1, 2009 | 07:19 PM
11secDSM's Avatar
Did you drill a hole through the firewall to run the power wire?
Old Mar 1, 2009 | 07:27 PM
urbanemyth's Avatar
thanks for the help guys, no i didntn drill throught the firewall i just ran through my fender ill seach for my relay stuff tomorrow...are they near my fuses?
Old Mar 1, 2009 | 09:36 PM
streetracerkam's Avatar
I have the same thing..
. The subwoofer/amp were removed though and these popped up.. and they were just taken from the trunk and the wire cut, so I have no clue how that could have caused this.
Old Mar 30, 2009 | 09:03 AM
urbanemyth's Avatar
Hey guys i didnt have muh luck finding the relays.... its not in the owners manual... im gonna have to take it in to Mitsu.... which i absolutely hate to do...
Old Mar 30, 2009 | 09:08 AM
Bggstin's Avatar
1. Check your TPS sensor.
2. Check your ACD Pump. You can prime it by holding the throttle at 100% while turning the key to ON, not Start....again if you havn't checked the TPS sensor and its the problem this wont work but you should hear the pump prime.
3. Check wheel speed sensors located at each hub and ensure that they look intact.
4. Go to Mitsu and have them check it...takes like 20min.
Old Mar 30, 2009 | 09:11 AM
evokid511's Avatar
sorry to thread jack but ive seen some other people ask when something goes wrong if you drilled a whole in the fire wall?? why is that what does drilling a whole in the firewall do?
