Jun 272/S2's
Old Mar 3, 2009 | 09:32 PM
05EvoVIII's Avatar
Jun 272/S2's
Hey guys im in the market for a set of really mean cams.. I was looking at the S2's from GSC then i found a pair of used JUN 272s.....What would you guys do. I have the AMS race head so i can go as big as i want
ANy imput would be awesome cuz i have the money just need a lil help.
Thanks
Brandon
Old Mar 3, 2009 | 09:38 PM
YzBrad99's Avatar
http://www.amsperformance.com/cart/T...mance.com.html
Old Mar 3, 2009 | 09:43 PM
05EvoVIII's Avatar
760 bucks! dayyyum! They seem pretty BA tho
But out of the 2 i asked about what 1 would you go with
thanks for your input dude
Brandon
Old Mar 3, 2009 | 11:21 PM
05EvoVIII's Avatar
b4 bed time buummppp
Old Mar 4, 2009 | 12:31 AM
Boost3dxEvO's Avatar
The last time I talked to Greg @ GSC about JUN 272s.. He quoted, "They used to be a very good cam, but now they are a thing of the past and there are so many more options and better ones at that.." The S2's seem to be very good since they have similar spool to stock and have very good gains all throughout the power band.. I would get S2's or BF 272s, which is what I'm going to run.. but then again, I usually run all buschur parts JUN's are good cams in my eyes though.. They just don't have as much lift as S2's, but then again.. its not all about lift either, especially since JUN's have a very aggressive ramp rate.. but in other words.. either or is fine !
Old Mar 4, 2009 | 04:01 AM
JC evo1's Avatar
Thanks
Brandon
i asked a similar question when i was choosing cams a while ago, this was before AMS came out with their big test. https://www.evolutionm.net/forums/ev...72-gsc-s2.html
Old Mar 4, 2009 | 05:38 AM
05EvoVIII's Avatar
WOW thanks so much guys! That thread helped a bunch! S2's here i come
Old Mar 4, 2009 | 05:41 AM
emilebazin's Avatar
I have brand new jun 272cams, springs and retainers.
Old Mar 4, 2009 | 10:18 PM
JC evo1's Avatar
you will like them, the drivability is great
Old Mar 5, 2009 | 05:16 AM
mandy1's Avatar
GSC2,flat power and torque band , lot of rpms and great idle with 14hg vacuum.see my signature for hp.all this with stock head,intake manifold and throttle!also BF272,you cant go wrong with any of them.
Old Mar 5, 2009 | 06:16 AM
turbodreamz21's Avatar
go with kelfords 272's they make alot of power and have the best power curve to the cams
Old Mar 5, 2009 | 06:17 AM
here is a test from AMS that tested the 2 cams you want plus others
https://www.evolutionm.net/forums/ev...-cam-test.html
Old Mar 5, 2009 | 10:27 AM
YzBrad99's Avatar
Go with the S2's for just one fact. If you have a problem with them or arent satisified im sure Greg at GSC will help you. I bought Cosworth M2 cams and they suck. The only difference was 10 hp more in the midrange and a lope idle. I wasent happy and cosworth didnt care. I wish i could switch to the S2's when i get my FP red.
Old Mar 6, 2009 | 05:35 AM
GregGSC's Avatar
Just to make matters more difficult for you..
we ground up a bunch of Jun Spec 272 10.8mm evo 8 cams.... yes same exact spec as jun. A customer sent in a set of jun cams and ordered a bunch to sell under there own name... welll the economy slowed and we got stuck with 30 sets of JUN 272 cams... if anyone wants them they are $500 a set same as our S1 or S2 Evo 8 Cams..
As far as what i would pair them on I think they would preform very well on a 2.3 or 2.4L with a decent sized turbo... the 1mm is pretty fat and will work great for a road race car probably something with a stock head or mild port...
Old Mar 10, 2009 | 10:57 AM
JFM13's Avatar
AMS just installed jun 272 cams springs and retainers. Car has ams fmic, lower pipe, apr head studs, ams fuel rail, ams turbo back exhaust with cat, arc intake, hallman mbc on a Stock turbo. Conservative tune 93 octane at 24.5 psi for winter. Made 343 hp and 352 torque
