temp gauge video
Old Mar 4, 2009 | 05:54 AM
FastAzzEvo's Avatar
temp gauge video
I been having some issues with extended idle....
If i begin driving it goes to normal op temps.. Never gets hot driving unless I turn on the heat...
Also, I do have heat... and a/c
The video speaks for itself.. I have logged it while its doing it and it wil be around 185-192 then when the gauge read HOT (H) its loggin 203 degrees nothing more...
I have burped the coolant system a few times make sure there is not any air bubbles..
I have never seen a gauge do this. I have seen one not work, I have seen one go hot stay hot and boil over, but never up and down like this.
Please help... I'm going today to ordera temp sensor...
direct link
http://www.youtube.com/watch?v=sbWPSNfNBRw
Old Mar 4, 2009 | 05:57 AM
ak47po's Avatar
Thermostat.
Old Mar 4, 2009 | 06:10 AM
Curt@MrLed's Avatar
Former Vendor
t-stat.
Old Mar 4, 2009 | 09:55 AM
FastAzzEvo's Avatar
if its ther t-stat wouldn't the car go hot and stay hot?
if its stuck closed?
I went to mits and my dealership never had a t-stat go bad on evo,, there have never ordered one.
I bought a sensor, but I am going to try one more time to burp it and make sure no air pockets are in there.
Old Mar 4, 2009 | 12:28 PM
FastAzzEvo's Avatar
fyi.... in case anyone has a problem like I had.. check your grounds. I spend 46$ on a sensor that I didnt' need.
I suppose the engine sitting unsupported awaiting my shep trans and twin disc caused my (what I think is the only) ground wire on engine to come apart.
Symptoms- car run hot idling when fan/ac would come on.... when fans kicked off the temp would go down on the gauge.
Jun 13, 2013 08:40 PM
Bones_OZ
Lancer Engine Tech
31
Oct 29, 2011 07:51 AM
EvolNinja
Apr 23, 2008 10:35 PM
EvilDylan
Oct 13, 2005 09:50 AM
DGS
25
Nov 24, 2004 02:56 PM
