Head gasket
Old Mar 4, 2009 | 10:06 PM
fvaldes's Avatar
Head gasket
Has anyone taken off the cyl. head and put it back on with the same head gasket? Just curious if it works.
Old Mar 4, 2009 | 11:20 PM
mrdecrypter's Avatar
no. its only $55 to prevent headaches. dont use the old one.
Old Mar 5, 2009 | 05:10 AM
JakeTheVIII's Avatar
It just wouldn't be worth the risk when they are only around $50. Would it work? Yea, probably. Not as good/long as a new one though. If you re-use the head gasket, you will be back in there in no time.
Old Mar 7, 2009 | 03:23 AM
3zero7's Avatar
with mild mods 24psi 264cams,arp studs, all bolt ons,what gasket thickness recommended?i.e. 1.0mm, 1.2mm etc...whats the difference and benefits anyways for each thickness?
i know we dont have to change the head gasketwith mild mods, but just a an extra insurance since im opening the head installing cams soon
Old Mar 8, 2009 | 11:57 PM
evofabulous's Avatar
why would you be taking the head off of your car anyways if the head gasket was alright to begin with unless you were installing headstuds. then you could do it the 1x1 way
Old Mar 9, 2009 | 01:57 AM
GRNCT9A's Avatar
I read somewhere the 1x1 way is wrong, someone chime in please.
Old Mar 9, 2009 | 03:45 AM
DIDYSIS's Avatar
I have seen it done but its not for me, in all thought prob all will be well but really is it worth guessing on it??
Old Mar 9, 2009 | 04:09 AM
Curt@MrLed's Avatar
Former Vendor
1 by 1. Its a 50/50 chance. Use a stock headgasket. They hold up to 800 horse.
Old Mar 9, 2009 | 04:20 AM
Kemist's Avatar
^ like he said, replace it while your there
Old Mar 9, 2009 | 05:08 AM
evo082006's Avatar
Yeah the removal of the head is the right thing to do for Head studs..You just need a new stocker gasket. Dont really need a thicker one unless you have a upgraded head with bigger valves..
Old Mar 9, 2009 | 07:48 AM
letMeIn's Avatar
dont' do it
Old Mar 9, 2009 | 07:57 AM
3zero7's Avatar
how abt the stock head studs...how much can it hold?
Old Mar 9, 2009 | 08:04 AM
justa4banger's Avatar
theirs alot of people with 600+ whp with them (arps)....
Old Mar 10, 2009 | 03:06 PM
Most people upgrade for safety when making over around 300-330 whp. They will take it, but running more boost will run the risk of them stretching.
Old Mar 10, 2009 | 03:16 PM
sslevo's Avatar
You should never re-use gaskets. Sure i have before when it doesn't really matter, but we are talking about the most important gasket on the entire car. I would say if you un-torque even one head stud the gasket may be compromised. Clean the head and block up and torque them evenly as recommended so the new gasket will compress properly.
EVO 4 life
Jun 29, 2016 08:28 PM
dsevo
Jan 1, 2014 09:10 PM
luislm21
Jun 3, 2013 12:55 AM
mitsugsx13
Mar 11, 2012 11:34 PM
czilla
17
Feb 1, 2010 12:40 PM
