clutch job need help!!
It's normal bro, that's the downside of aftermarket parts, they perform better but you sacrifice driveability
You hear it the most when the car is at a stop because that's when the most amount of friction is being applied between the clutch disc & the flywheel. When you're moving both the disc & the flywheel are moving so there is less friction involved along with less noise. Different clutches use different materials to promote grip/grab and the downside to some materials is noise.
Has the noise ever come back?? Should I go launch mine twice lol?
I started getting the noise with about 200 miles on my CC stage 4. I as of now have just under 500 miles on it.
