help need ideas
Old Mar 9, 2009 | 10:30 AM
steevo 8's Avatar
help need ideas
so my car has been making a clunk clunk noise everytime i turn right. replaced the axles not the problem..... it has been doing it for the passed 5k miles and doesnt not charge with speed. any ideas would be great
Old Mar 9, 2009 | 11:42 AM
evane's Avatar
i had a clunk/ click noise coming from my drvier side front wheel but it was only when I turned the steering wheel at a stop or taking off from a stop...ended up being the sway bar linkage was loose....have you check to see if it could be a wheel bearing?
Old Mar 9, 2009 | 11:57 AM
RandomDj's Avatar
is it harmonic? is it more of a click or a thud?
as said above... it could be ur wheel hub...
other things to check/retorque:
-ur camber and safety bolt at the bottom of the strut
-ur lugnuts (sounds stupid but it has happened)
Old Mar 9, 2009 | 12:14 PM
evane's Avatar
check those....on my eclipse i started getting this clunkin noise from my front driver side wheel and thought i screwed up the axle but got home and the lugs we loose but i guess if you had the axles replaced and the problem presists then its pry not the lugs
Old Mar 10, 2009 | 12:32 PM
steevo 8's Avatar
its more of a thud than a click and checked the wheel hub. checked the sway bar. lugs are good. and its the same sound if im pulling in my driveway rolling or im taking an exit ramp at 60mph.... thanks for the input. anymore ideas?
Old Mar 10, 2009 | 12:33 PM
steevo 8's Avatar
also checked the stuts.
Old Mar 10, 2009 | 12:43 PM
roger smith's Avatar
Also could be suspension spring shifting in the perch.
Do you have stock suspension?
Old Mar 10, 2009 | 02:58 PM
steevo 8's Avatar
it started with stock suspension. then i changed to tanabe spirngs and replaced the bushings and still does it.
Old Mar 10, 2009 | 07:09 PM
steevo 8's Avatar
bump
Old Mar 11, 2009 | 07:50 PM
steevo 8's Avatar
well car is off to turbotrix tomor. lets hope they can find thins thud and fix it
jdogstoll23
May 9, 2016 09:34 AM
Dmarianodesign
Sep 4, 2014 03:47 AM
MLEVO1
Nov 2, 2012 06:29 AM
KamClem208
Apr 29, 2012 09:30 PM
DrShio
10
Jun 29, 2006 12:21 PM
