Intake manifold, reinstall help etc
Old Mar 9, 2009 | 11:56 AM
DIDYSIS's Avatar
what stuff can I Delete off the Intake manifold?? Or do I need it all? Also took it all apart and have most lines hooked back up but still not sure about some, any help with where to plug what?? Thanks much large pics of the hoses and such would be great.
Old Mar 9, 2009 | 11:57 AM
Johnboy1065's Avatar
depends man, are you running the stock ecu or stand alone? and if it's the stand alone are you still running MAF or are you running speed density?
Old Mar 9, 2009 | 12:12 PM
evane's Avatar
i disabled the EGR on my car thru EcuFlash and plan on blockin the EGR off when i sent the intake and throttle body in to have it ported and 65mm TB service
Old Mar 9, 2009 | 12:21 PM
DIDYSIS's Avatar
I am on the Stock ECU, Dont have Emition test, have a 3.5inch GM maf working on setting it up as a blow through, can you setup a speed density on a stock ECU and how do you?? Tried looking for that info and could not find it anywhere really.
Old Mar 9, 2009 | 12:25 PM
evane's Avatar
i'm not totally sure but i think you can setup a speed density setup with the stock ecu along with the JDM MAP sensor? i'm not sure tho...you would have to look into that one...why did you go with a blow-thru setup when the capabilities of the stock ecu/ maf are amazing!
Old Mar 9, 2009 | 12:28 PM
o7'silvermax's Avatar
well if you look at an aftermarket intake manifold what do they have?
Old Mar 9, 2009 | 12:36 PM
evane's Avatar
an aftermarket manifold will still have a place to bolt on the factory MAP sensor you would think but it might have a bung for an AEM MAP sensor....Buschur makes and adapter plate for the AEM map sensor that bolts to the factory map sensor location
Old Mar 9, 2009 | 12:48 PM
DIDYSIS's Avatar
I found someone that wanted to trade a stock Maf for a full GM maf setup so I went for it and I heard anyways that the stock does start to hurt power after a while and have to be cautions of the screen. And I like to be different and though it was a good deal. I AM STILL ON STOCK ECU!! and love it, just need to do more things to it like the knock cell flicker etc. know something still learning others.
Old Mar 9, 2009 | 01:21 PM
scheides's Avatar
EvoM Moderator
You can delete a LOT of stuff if you search through the ecuflash section.
CahitGP034
Jan 6, 2016 12:58 AM
Hamish
Oct 17, 2012 04:11 AM
bbyevo8u
16
May 16, 2011 08:06 PM
MDH-005
Evo X How Tos / Installations
Jan 16, 2009 11:36 AM
Buksh
85
Oct 25, 2007 10:10 AM
