intake manifold - help
Old May 14, 2011 | 09:29 PM
bbyevo8u's Avatar
i just noticed that at the end of my intake manifold i have an open nipple? next to the oil dip stick there's a brass bracket that holds an electrical harness and what looks like a nipple for vac or something, can someone please tell me what this is for
i been looking for intake manifold diagrams but i cant find anything that tells me what its for
Old May 14, 2011 | 09:40 PM
wizzo 8's Avatar
A picture would do wonders
Old May 14, 2011 | 09:44 PM
FedEvo8's Avatar
My guess is the MAP Sensor?
Old May 14, 2011 | 10:01 PM
bbyevo8u's Avatar
ill get a picture up in the morning!
hey fedevo if it is the map sensor then where should the hose go too?
thanks!
Old May 15, 2011 | 02:05 PM
bbyevo8u's Avatar
i been trying to get a picture up but i cant at the moment!
can someone take a look at there manifold and tell me where that hose go too, please!
Old May 15, 2011 | 02:23 PM
Kracka's Avatar
That's your fuel pressure regulator solenoid. Post a pic of that area...but I'm guessing it was bypassed.
Old May 15, 2011 | 02:27 PM
The-Evo's Avatar
It might be your fuel pressure solenoid. I see a lot of guys not running that vacume.
Old May 15, 2011 | 03:47 PM
bbyevo8u's Avatar
i have a check engine light on and i got the code pulled - p300 / random multiple misfires im not sure if this is whats throwing the code or not?
can i t-tap into the fuel pressure regulator vac line for boost gauge reading?
thanks for helping guys!!
Old May 15, 2011 | 04:31 PM
BLKCarbonEVO's Avatar
I agree with Kracka
Ya you can but I just run mine off the manifold.
Mikey
Old May 15, 2011 | 04:53 PM
bbyevo8u's Avatar
Originally Posted by BLKCarbonEVO
I agree with Kracka
Mikey
which line do you tap into off the manifold?
my FPR vac line go's to a nipple on the top left side of the manifold, i found a engine bay picture of the nipple that my FPR vac line is hooked up too but the picture show it different, the top left nipple on the intake manifold jumps rite over to the nipple on the side of the manifold thats on the brass bracket i spoke about in the beginning of the thread and the FPR vac line go's under the manifold in the picture, im so confused rite now
Old May 15, 2011 | 05:31 PM
Really any vacuum hose will work. Just pick one. You are not going to mess anything up.
Mikey
Old May 15, 2011 | 05:32 PM
bbyevo8u's Avatar
at the top of the picture you see the open brass nipple, should it be capped off or hooked up?
i really want to know why im throwing a p300 random multiple misfire code
Thanks for helping Mikey!!
Attached Thumbnails intake manifold - help-2011-05-15_20-18-48_828.jpg   intake manifold - help-2011-05-15_20-19-02_288.jpg
Old May 15, 2011 | 05:48 PM
Cap it if you want but your misfire is prob your plugs... How many miles you have on them? What is the gap?
Mikey
Old May 16, 2011 | 05:51 PM
bbyevo8u's Avatar
spark plug are new but i pulled and checked them anyways, i disconnected the battery to see if the engine light would go any but it didnt
anyone ever get this "p300 random multiple misfire" code before?
Old May 16, 2011 | 07:57 PM
The-Evo's Avatar
Take your plugs out and check the gap. What spark plugs are you running? This will cause the problem also. If you are not sure how to do this, please have a certified mechanic do this for you. As for the Check engine light. Do you mean P0300? That stats a random misfire, commonly caused by a faulty coil, spark plugs, o2 sensor, egr, or fuel injectors. My guess is, that your egr vacume hose has popped off. Are you running a test pipe(catlytic converter)? If so, you will need a cel fix or have a tuner disable this o2 for you?
