my intake cam snapped?!!?
Old Mar 23, 2009 | 02:55 PM
  #286
SRT-TO-EVO's Avatar
Well guys good news from Kelford. Kevin has asked me to send the cams I have back (they are brand new in the box), and if I want, get the same grind on the FP cam. I think this is definitely the route I will be going with (let's just hope no FP cores start snapping lol).
Old Mar 23, 2009 | 03:18 PM
  #287
vmrevo9's Avatar
Veteran: Air Force
wouldnt regrinding cams make them weaker?
Old Mar 23, 2009 | 03:31 PM
  #288
SRT-TO-EVO's Avatar
Lol, no they're going to use the same core as the FP one. Not regrind an actual FP cam, I don't even think that's possible.
Old Mar 23, 2009 | 03:54 PM
  #289
MattyBoyMR's Avatar
Yea i got what was left of my cam out today and it was the one the EHH8 batches..like all the other kelfords that ive seen. So i think is is the bad batch theory...
Old Mar 23, 2009 | 04:34 PM
  #290
vmrevo9's Avatar
Veteran: Air Force
gotcha
Old Mar 23, 2009 | 04:53 PM
  #291
itzcharlez's Avatar
mostly this thread has been about gsc and kelford cams snapping right? if there some stories of cosworth cams snapping as well?
Also could it be possible that the cams snaping is due to the springs your running with your cams? i know some springs are harder to compress than others. This could cause added resistance leading to the cams snapping.
Sorry if this has already been covered...
Old Mar 23, 2009 | 05:33 PM
  #292
KevinD's Avatar
i just got Booster9's broken kelford cam. it was from the EHH8 group. lets start a list of broken cams and the casting code.
Booster9: Kelford 272, EHH8 casting code, installed in first week of september '08, broke feb/march 09. stock valve springs, stock retainers, stock MIVEC tables.
TNT1106: GSC S2, EHH8 casting code, installed last week of august '08, broke in jan/feb '09. GSC beehive springs, stock retainers, slightly modified MIVEC tables.
Old Mar 23, 2009 | 06:18 PM
  #293
MattyBoyMR's Avatar
MattyBoyMR :Kelford 272 EHH8 casting code purchased Aug. 10, 2008 Installed not long after i recieved them. Broke March 21, 2009 at 7:45pm. Supertec dual springs and retainers, stock mivec tables
Old Mar 23, 2009 | 08:09 PM
  #294
vmrevo9's Avatar
Veteran: Air Force
wow so far this batch only lasted around 5-6 month of use on both sets of cams.
Old Mar 23, 2009 | 08:10 PM
  #295
PawelTokarz's Avatar
Kelford has been working diligently to find the cause of the mivec cam breakages. We appreciate the useful feedback most of you have been giving us that we can use to help pinpoint the problem.
As pointed out by Kelford earlier in the thread, the cams that are currently being supplied to Motovicity (and have been sold since Feb of this year) are the same as used in the FP cams as well as a few other cam companies out there. We have not had any reported failures of these cores. Until the exact cause of the failures has been pointed out in the other cores, these cores will be used. For all we know it could be something as simple as damage in shipping, which we have also switched our packaging to further protect the cams.
The difference for the two cores is obvious, see pictures attached, both Kelford cams. The picture with the shallower oil grooves is the current core we have been selling.
We have also replaced a few of the old cores from customer that have came to us with concerns.
We do recommend running Bee Hive springs with the evo 9 cams, we do not recommend using dual valve springs.
Pawel - Motovicity
Attached Thumbnails my intake cam snapped?!!?-image001.jpg   my intake cam snapped?!!?-image002.jpg
Old Mar 23, 2009 | 10:23 PM
  #296
93 3gt vr4's Avatar
PawelTokarz do you know what the casting number is/ are for the fp cams? Or the kelfords with the same blanks as fp? Does anyone know which is which for cores and casting numbers?
Old Mar 23, 2009 | 10:32 PM
  #297
itzcharlez's Avatar
how do i know what casting code my cam is..
Old Mar 23, 2009 | 10:38 PM
  #298
93 3gt vr4's Avatar
if installed you can see it through the oil cap with the engine in the right position. Otherwise it shown in post #214 in this thread.
How much resistance is there, if you don't bleed the lifters? Maybe that accelarates the breakage?
Old Mar 24, 2009 | 08:58 AM
  #299
shuttlegoose's Avatar
so have we figured out what cams aren't in the failure test group yet???
Old Mar 24, 2009 | 09:34 AM
  #300
itzcharlez's Avatar
can the companies come forth and say from what time to what time the EHH8 cam was used for production?
if failure is from the EHH8 group.
