Bar to PSI conversion.
Old Mar 14, 2009 | 07:18 PM
AcePitcher11's Avatar
I need to know what vacuum my car is making at idle so I can get the right spring for my Tial BOV but I have a Defi boost gauge which is in bar and I'm not sure how to read the vacuum numbers. Around idle when the car is warmed up the needle seems to hang right at 0.6 so can anyone tell me what that would be in PSI vacuum?
Old Mar 14, 2009 | 07:21 PM
JRB_EVO's Avatar
1bar is roughly 14.5psi, therefore 0.6bar of vaccum is about 8.7psi
Old Mar 14, 2009 | 07:23 PM
Well vacuum would be negative so -8.7 right?
Old Mar 14, 2009 | 07:33 PM
Levar's Avatar
Veteran: Army
Hopefully this will put you on the right path.
http://www.justchil.net/psi2bar.html
Old Mar 14, 2009 | 07:38 PM
Cali2MDevo8's Avatar
Registered User
I downloaded "units" to my iPhone for free. It has almost every measurement conversion and does it for you!!!
1 bar: 14.50377373066 psi
LOL
Old Mar 14, 2009 | 07:41 PM
JRB_EVO's Avatar
Vacuum implies negative pressure!!!
Old Mar 14, 2009 | 07:45 PM
sho669's Avatar
PSI - BAR - Kpa - mmHg - kg/cm.sq
1.45 - 0.1 - 10 - 75.01 - 0.102
2.90 - 0.2 - 20 - 150.02 - 0.204
4.35 - 0.3 - 30 - 225.03 - 0.306
5.80 - 0.4 - 40 - 300.04 - 0.408
7.25 - 0.5 - 50 - 375.05 - 0.51
8.70 - 0.6 - 60 - 450.06 - 0.612
10.15 - 0.7 - 70 - 525.07 - 0.714
11.61 - 0.8 - 80 - 600.08 - 0.816
13.06 - 0.9 - 90 - 675.09 - 0.918
14.51 - 1 - 100 - 750.1 - 1.02
15.96 - 1.1 - 110 - 825.11 - 1.122
17.41 - 1.2 - 120 - 900.12 - 1.224
18.86 - 1.3 - 130 - 975.13 - 1.326
20.31 - 1.4 - 140 - 1050.14 - 1.428
21.76 - 1.5 - 150 - 1125.15 - 1.53
23.21 - 1.6 - 160 - 1200.16 - 1.632
24.66 - 1.7 - 170 - 1275.17 - 1.734
26.11 - 1.8 - 180 - 1350.18 - 1.836
27.56 - 1.9 - 190 - 1425.19 - 1.938
29.01 - 2 - 200 - 1500.2 - 2.04
I found this a while back, hope it helps
Old Mar 14, 2009 | 08:18 PM
sho669's Avatar
ok re-read the first post, why don't you just pick up a vacuum gauge from the parts store? I'm sure you can get one for like $20 like I did, use mine for tuning carbs though! Then you wouldn't have to guess.
Old Mar 14, 2009 | 08:48 PM
Ok just to make things stupid proof so I can get this part ordered here is the chart for vacuum and my gauge reads -0.6 Bar so is it the black spring that I need or a different according to this chart.
mattchan99
23
Jan 10, 2014 04:28 PM
ImsoevoX
Evo X How Tos / Installations
37
Apr 26, 2013 12:28 PM
matrho2792
Aug 2, 2012 06:29 PM
hyeteck
May 24, 2011 07:23 PM
MattyBoyMR
Mar 19, 2009 09:13 PM
